-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   N95 flashed ok but cant do pen cailbration (http://forum.gsmhosting.com/vbb/f296/n95-flashed-ok-but-cant-do-pen-cailbration-448605/)
dompezvicky 09-28-2007 15:44
hello friends
i had to flash my N95 (chineese miracle) up to ten times with different files, at last i got one file that made it work, ask file made and converted to rpl and writen in phone all ok, but i cant use the stick or pen on the LCD.
IS THERE ANY KNOWN SOLUTION TO THIS HEADACE? :confused:
InfinitySupport 09-28-2007 15:58
Probably you need to use other flash file, it may be that your phone hardware not compatible with current firmware.
dompezvicky 09-29-2007 07:51
thanks for the option given, but i have used almost all the files available. so i should keep trying?
InfinityHelp 09-29-2007 12:16
hello!
if you dont know/dont have original version of your phone- then yes, you must ry them all
virgin_phones 09-29-2007 13:07
i also have the same problem but my case screen is white screen. i tried all files names with pda because my phone is n95 pda. or should i try other files which are not for pda?
InfinitySupport 09-29-2007 14:59
Yes, you can try to use other files. Main thing is firmware version name but not phone name, so find files with similar firmware version and flash it (model name is not so important)
Page generated in 0.15019 seconds with 5 queries
