Old 04-21-2009, 06:08   #1 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
n95 new bord ... need pinout???
need n95 pinout............
Old 04-21-2009, 09:39   #2 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
did u tried manually by selecting the pinouts using cable L10c
rx 7
tx 8.
if u fail in this way try to find out pinouts using multimeter.
br
hamid
Old 04-21-2009, 11:27   #3 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
rx 7
tx 8.
br
hamid
plz uplode pic .... i tried 6/7 pin but not sucess...
Old 04-21-2009, 12:12   #4 (permalink)
Member: 190344
Thanks Meter: 280
did u tried cable u L4A from handfree pin of phone?
no picture of this phone in my data base.
Old 04-21-2009, 19:02   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i am sure that pinout is hidded in system connector.
if you dont have pinfinder to find it- i can teach how to find it using multimeter
Old 04-22-2009, 04:12   #6 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 571
hello!
yes plz teach me ...
Old 04-22-2009, 22:58   #7 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached, phone can be powered On or not)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
need pinout sigmatel fxd 3600 bassemzini Infinity-Box 0 03-29-2010 19:22
Need Pinouts for new-N95-8gb this pcb azeem781986 Chinese Models & Cloned Phones 1 09-08-2009 17:42
Need pinout nokia new n95 rh19 farhanali Infinity-Box 5 08-07-2008 22:57
N95 Cable Broke..Need Pinout sharaz191 J.A.F. V-SPEC 2 02-26-2008 06:03
need pinout for new n95 kikouch Infinity-Box 1 01-13-2008 05:17
Page generated in 0.16390 seconds with 9 queries
