Old 04-24-2008, 17:18   #1 (permalink)
Member: 743742
i want know which part are detected.
please share ur experience, now i formated one dual sim cm, please tell me which part are setected, part a or part b. how i know?
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:035B:69ED
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: E550_A5FRENCHBT.01.1_26S01
Version: M500Z_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 35410100022849
connection Ok
building list...
done
items to clear: 200
181 of 200 items cleared
building list...
done
0 items remains
Finished, time used: 122 sec
Remove/Install battery now !
Old 04-24-2008, 18:43   #2 (permalink)
Member: 743742
http:///vbb/showthread.php?t=529071
please give a proper replay bcz some post infinity supporters saying use reverse some one saying solder. confused.
if pinfinder not detecting second mcu its bad news.
Old 04-24-2008, 19:49   #3 (permalink)
Member: 583680
Thanks Meter: 47
19200 autodetect
CPU: MT6226
Connecting, wait...
Date: 2005.04.12
Version: 1.0
done
60 byte(s) read
connection Ok
building list...
done
items to clear: 200
building list...
done
0 items remains
Hello!
In Your case You have detected CPU1,see Your log (MT6226).
Before You start playing with phone-first make backup of fullflash.After You have done it-compare both backup_flash_*********xx.bom.bin files.Main CPU flash file usualy is 7-10 Mb,second CPU flash file is 1-3(max 4)Mb.
Good luck!
ezzis
Old 04-24-2008, 20:28   #4 (permalink)
Member: 743742
Originally Posted by ezzis View Post
Hello!
Good luck!
ezzis
if i get cpu2 what log will show?
Old 04-24-2008, 20:40   #5 (permalink)
Member: 583680
Thanks Meter: 47
almost the same,except CPU type will be lower than 6226.But also CPU1 may be Mt6225.Best way to know which CPU is detected is to read fullflash.
Old 04-24-2008, 20:52   #6 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
Oi
2nd cpu 90% mt6205
wbr
how to know which activations are active on my ub box hafiz_anjum Universalbox 2 07-21-2009 09:51
(n70) i want to know which components are required for network with diagram asif_ae Nokia Hardware & Hardware Repair 1 06-06-2009 16:19
Which parts are compatible? Frogy DJ Nokia Hardware & Hardware Repair 3 09-01-2008 11:30
How To Know Which Languages Are Inside A Firmware ?? tsarkh BlackBerry (RIM) 1 06-20-2008 09:16
how to know which languages are in flash files? yakety Nokia Base Band 5 ( BB-5 ) 3 02-07-2008 12:19
Page generated in 0.14750 seconds with 9 queries
