Old 10-09-2008, 07:37   #1 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
n95 With PIN code it HANG without PIN ok!
i have a CHINESE mobile when you PRESS pin cODE the phone stuck here : Pin code accepted.... But when i insert a SIM card without PIN the PHONE is OK!!!!!
Can i used another version of flash file? Please guide.
OM4 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031711:E56A
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.06B.W07.04.MP.V32
Version: N95_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35307901120235
connection Ok
building list...
done
items to clear: 181
warning: wrong packet cs
167 of 181 items cleared
building list...
done
0 items remains
Finished, time used: 97 sec
Remove/Install battery now !
Old 10-09-2008, 17:10   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
Hello,
Are you sure that it's problem with phone but not with SIM card ?
Did you tried to use another sim cards ?
Old 10-09-2008, 21:39   #3 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
Originally Posted by InfinitySupport View Post
Hello,
yes i did tried wit hanother SIM card
But SAME after tried to flash with another FIRMWARE the phone is ON but the DISPLAY is very bad .. and it does not stuck on CODE ACCEPTED Anymore!! How to identify the right FIRMWARE to use on such mobiles... !!!
Old 10-09-2008, 23:53   #4 (permalink)
Member: 148515
Thanks Meter: 15,716
hello!
First of all you must make "read detailed information" and then pick correct flash file.
here is step-by-step tutorial how to make this:
One Method for Find Flash File in Infinity Support Site
Old 10-10-2008, 08:14   #5 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031711:E56A
high speed disabled
boot step size: 0002
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9FF4AE26.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_B66274F4].rpl
identification#1 detection finished
device-id: 9FF4AE26
identification#1 protocol ver: 04
ver. sw1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN
ver. sw2: MAUI.06B.W07.04.MP.V32, 0B8B9D49
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: F:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_9FF4AE26_N95_PCB01_GPRS_MT6226_S01.MAUI_ 06B_W07_04_MP_V32.BIN_B66274F4_20081010-100832.B0X.bin
Finished, time used: 181 sec
But now which one to choose????
From search i got:
flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs_01.B0E.bin
flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs_02.B0E.bin
flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95.B0E.bin
flashfiles/ChineseMiracle/_MT6226/repair_eeprom/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95_8GB.B0E.bin
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95-8G_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V3 2_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V 32_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/CM_Nokia-N95_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V 32_16m_En_Ru_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar_ver2.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_ver2.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_N okia-N95-8GB-RM17_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.b in
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ N95-8Gb_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Farsi_Ar.B0M.bi n
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ N95_16m_En_Ru_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb-RM-17_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb-RM-17_double-slider_L10C_16m_En_Ru_Fr_Es_Hu_It_Ro_De_Cn.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8GB_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_v2.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_v3.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-8GB_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_ver2.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-RM13_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95-slider_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ Nokia-N95_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_8Gb_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_16m_En_Ru_Fr_De_Id_Th_Vn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ NOKIA_N95_16m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95-1_32m_En_Ru_Fr_Ml_Id_Vn_Cn_Cn_Ar__w_eeprom.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95_8GB_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _n95_8GB_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _NOKIA_N95_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.b in
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _NOKIA_N95_16m_En_Ru_Fr_It_De_Id_Th_Vn_Tr_Ar.B0M.b in
flashfiles/ChineseMiracle/_MT6226/N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ __N95_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M.bin
End of search (35 found)
Old 10-10-2008, 08:15   #6 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
and after flash i should make EEprom repair... what are the step after flashing???
Old 10-10-2008, 16:29   #7 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031711:E56A
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
device-id: 9FF4AE26
ffs chip: 00
From search i got:
Please Which flash file i should choose !!
Old 10-10-2008, 19:35   #8 (permalink)
Member: 130995
Hello,
You can select any of them, better select file with langauges that you need.
If first file is not Ok you need to use another one etc.
So you will be able to find firmware that is suitable for your phone.
Old 10-10-2008, 20:32   #9 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
Thank you !! But on last thing, should i write EEPROM? Or let it as the same!!!
Old 10-10-2008, 22:04   #10 (permalink)
Member: 148515
hello!
write firmware only, check phone behavior, if still problem with pinicode- makeformat FFS complete
Old 10-14-2008, 07:47   #11 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
I have tried may FLASh file but all of them are giving me the same PROBLEM... the Display become like TV but you can see the the FONTS.. its like Windows Contrast Theme... If i flash with it own Flash file it become OK. What should i do NOW???
Old 10-14-2008, 16:36   #12 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
Ok problem SOLVED... but flash file was not located on the SERVER. Today by great chance a CLIENT being a CHINA phone n95 same look with the above MODEL am referering to, but the software is differnt and does not have the problem of SIM card. So i copy its FIRMWARE and send it to the PHONE ... and EUREKA... the phone is working and the problem of SIM is GONE...
ProbleM : Freeze on Pin Code Accepted
Solution: Flash with,
KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN_20081014-160536.B0M.bin
Old 10-14-2008, 16:45   #13 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
hello!
Hello SIR, i was thinking about SOMETHING if the above solution make the phone work again mean that i flash the phone with eeprom of the other phone also.. becasue i read the other phone FULL FIRMWARE... Meaning that the flash file in server are FULL or only FIRMWARE??
Old 10-14-2008, 20:26   #14 (permalink)
Member: 148515
hello!
all flas files on server is Firmware Only, unless you see at the end of file "w_eeprom"
Old 10-15-2008, 04:08   #15 (permalink)
zakiyyboss's Avatar
Member: 64823
Thanks Meter: 409
hello!
Ok thank you. So you do not think that my problem was not solved because i flash only FIRMWARE and not eeprom with the FIRMWARE on the Server? So can you post FIRMWARE with eeprom ?
n95 with 1.04 error and with 1.03 unlock ok balanel JAF No Tp Unlocker by Cinek 3 02-26-2009 15:37
6230i hang and turn off, without sim ok... please help .:.GSM-ANGEL.:. Nokia Digital Core Technology 4 ( DCT-4 ) 9 04-18-2008 13:47
n95 without pin ok, with pin hang Proxy Infinity-Box 4 03-25-2008 03:22
8380 with sim no power but without sim ok. Softway LG 11 04-04-2007 11:29
Rel. 5.00 with only one provider without PIN ? dadleit Sim Cloning and Scaning 16 04-13-2003 12:07
Page generated in 0.53290 seconds with 9 queries
