Old 02-25-2008, 14:16   #1 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
N95 rh-19 chinese Rebooting when making call?????
Of recent, most chinese miracle N95 rh-19 are developing a particular problem, After u dial a number on the phone and hit the send button, the phone will just reboot and come back on. We have over 30pcs of these phones with this problem. We've tried formatting, flashing, and even re-heating the pcb but without success. Pls infinity, can u confirm this and let us know which step to take. Or is it a problem from factory. All phones developed the same problem all in the same period. Whats the way out of this?????????????
Old 02-25-2008, 23:26   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we discussed this problem few times and found that this is network operator fault.
Did you try to use same phone in other network? what is result?
Old 02-27-2008, 07:01   #3 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Yes we have about 3 networks functioning here but when using 2 of the networks, the phone reboots when making or recieving calls but when using the third network, it remains stable.
Old 02-27-2008, 07:04   #4 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
Format Ffs Complite Ur Problum Is Solev .goodluck..
Old 02-27-2008, 11:47   #5 (permalink)
Member: 148515
hello mr. Parminder Singh!
he said he try everything like formatting, flashing, and even re-heating the pcb but without success
Old 03-08-2008, 09:40   #6 (permalink)
Member: 476739
Thanks Meter: 507
yes i will last option is one (CHANGE THE C.P.U) GOOD LUCK
The Following User Says Thank You to Parminder Singh For This Useful Post:
Old 03-11-2008, 00:50   #7 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
HEHEHEHEHEHEHEHE WAIT FOR INFINITY HELP TO GIVE A SOFTWARE OPTION
Old 03-16-2008, 14:45   #8 (permalink)
Member: 241111
it still deos not workmout this problem is driving people mad
Old 05-08-2008, 07:17   #9 (permalink)
Member: 98928
Thanks Meter: 464
nokia n95 rh-19
same problem with me
when you hit on call the phone restart and when you recive too?
itry all (reflash formating ...) not work
Old 05-08-2008, 09:27   #10 (permalink)
tarunvishal's Avatar
Member: 308296
Thanks Meter: 152
try this solution and repay me
File Type: jpg rf3146 sending closed phone problem.jpg (184.2 KB, 48 views)
Old 10-01-2008, 21:57   #11 (permalink)
Member: 42981
Sonork: 1583521
Thanks Meter: 9
what do you me buy swarp
how take it off or brige it
Old 10-02-2008, 12:59   #12 (permalink)
Member: 148515
hello!
try this solution before soldering:
http:///vbb/showpo...96&postcount=6
Old 10-05-2008, 10:24   #13 (permalink)
Member: 42981
Sonork: 1583521
Thanks Meter: 9
the code worked with the rh 19 n95 rebooting when making calls
Old 10-05-2008, 13:40   #14 (permalink)
Member: 162536
Thanks Meter: 5
Please what Code are you talking about. I need the Code to solve similar problem.
Thank you.
Rangeric
Old 10-05-2008, 17:33   #15 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Exclamation
Thank you.
Rangeric
in n95 use *#3646633# ...go to misc. setting set amr to turn off... then restart the phone & check & post result.
N95 goes of when making calls. NERRO Chinese Models & Cloned Phones 4 08-24-2009 19:47
N95 Rh-19 Rebooting ATIEFUOR-GSM Infinity-Box 12 09-09-2008 18:02
Nokia N95 RH-19 need help. manja022 Infinity-Box 2 01-05-2008 10:17
V3 reboots when answering calls rampe Smart-Clip 2 02-22-2006 10:18
3210 reboots when you call Hanukkah Nokia Hardware & Hardware Repair 0 11-19-2001 02:44
Page generated in 0.27708 seconds with 10 queries
