11-11-2008, 12:22 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | N95 Rm 159 deadset done with INFINTIY disassemble phone connecting pinouts to phone (tx rx and ground from box to phone) thank u boss cayton backup flashfile on chinese miracle then format FFS (complete) COM25 [VCP0] selected module v2.66 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:BF8C:4458 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.DB2F2710.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN_103A0BEB].rpl identification#1 detection finished device-id: DB2F2710 identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN ver. sw2: B10_EFATRIS_V1217A, 14F4C5EF ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN]... file saved: D:\Chinese miracle backups\Back-up eeprom\N95-rm159 single sim\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V1217A .BIN]_20081109-222725.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_DB2F2710_T6226_05C_PCB01_GPRS_MT6226_S01 .B10_EFATRIS_V1217A.BIN_103A0BEB_20081109-222904.B0X.bin Finished, time used: 457 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to topnoyze For This Useful Post: |
11-11-2008, 19:41 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @topnoyze Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
n95 rm-159 cant unlock with zolea2.1 | yahia ali | Nokia Base Band 5 ( BB-5 ) | 0 | 08-30-2009 17:24 |
N95 RM-159 V.21.0016 UNLOCK DONE WITH NEW JAF_Nokia_BB5_Unlocker_103 | yasermalik | JAF No Tp Unlocker by Cinek | 8 | 01-19-2009 16:11 |
n95 rm-159 ver 12.0.23 unlock done | omer123 | BB5 No TP By Jafsupport | 0 | 12-11-2008 23:29 |
N95 RM-159 Not working with Thomas No TP | TDKI | BB5 No TP By Jafsupport | 5 | 11-28-2008 17:46 |
n95 - rm-159 done with error | gsm_era | BB5KING | 4 | 11-20-2008 10:49 |
