10-21-2008, 09:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | N95 slider format failed COM3 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F22F:23C7 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 98 sec Remove/Install battery now ! B.R thushdt |
10-21-2008, 10:33 | #2 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Successful format after using “complete mode” & low baud rate. Phone alive now ………….. COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:F22F:23C7 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B61DFDF4.[N618_PCB01_GPRS_MT6227_S01.BIN_C3A0516F].rpl identification#1 detection finished device-id: B61DFDF4 identification#1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.BIN ver. sw2: N618.1, 90AE5F3C ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B61DFDF4_N618_PCB01_GPRS_MT6227_S01.BIN_ C3A0516F_20081021-143415.B0X.bin Finished, time used: 162 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BIG THANK FOR INFINITY TEAM ....... B.R thushdt |
The Following User Says Thank You to thushdt For This Useful Post: |
10-21-2008, 18:34 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Nokia-N95 slider sucessfully format by ET BOX | moyalaslam | ET-BoX | 1 | 02-12-2008 09:32 |
Looking for N95 slider pinout | kasner | Infinity-Box | 8 | 01-19-2008 19:20 |
N95 slider can't format | Clinika | Chinese Cocktail | 1 | 12-17-2007 09:52 |
plse give me the true pinout for n95 slider | laythjg09 | Infinity-Box | 10 | 12-05-2007 04:52 |
*-* worked Nokia-N95 slider pin out *-* | mr.6630 | Chinese Cocktail | 5 | 10-09-2007 12:28 |
