09-17-2007, 10:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2002
Member: 17851 Status: Offline Thanks Meter: 151 | N95 Unable to connect (CPU 6226) pins are : 1X12 did the 1,6,7 - GND RX TX Unable to connect--- cpu: mt6226ba 0721-boal cp3mj8 flash; samsung k5l2731camd770 ulc252p6 must be new security or hardware? ...preparing email to infinity-team |
09-17-2007, 10:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, There is no any reason to think about serious things like "new hardware" or "new security" or something like this. You have ordinary easy cable problem, nothing else. In most cases this kind of problems can be solved bt easy reading w/o any kind of hardware or security research. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 |
09-18-2007, 15:41 | #3 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 42
Member: 152846 Status: Offline Thanks Meter: 12 | [QUOTE=gesundheit;2719944]N95 Unable to connect (CPU 6226) pins are : 1X12 did the 1,6,7 - GND RX TX Unable to connect--- cpu: mt6226ba 0721-boal cp3mj8 flash; samsung k5l2731camd770 ulc252p6 must be new security or hardware? n95 pin out 100% correct according to .txt file provide by infinity team.i just do it very simply yesterday.try to change rx,tx each other.if u checked properly rx & tx lines comes to side resistors and u can connect ur wires there more easy. try it again .... br. |
09-21-2007, 04:28 | #4 (permalink) |
Member: 17851 Status: Offline Thanks Meter: 151 | SOLVED COM25 [VCP1] selected Device: Autodetect 6205-6227,6228 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.D515FA24.[N618_PCB01_GPRS_MT6227_S01.1.BIN_51959CA1].rpl identification detection finished device-id: D515FA24 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]]... file saved: backup_eeprom[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20070921-102841.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: EC257E25082501:29EA0000000000 Write Done file saved: backup_system_log_D515FA24_N618_PCB01_GPRS_MT6227_ S01.1.BIN_51959CA1_20070921-102857.B0X.bin Finished, time used: 316 sec Remove/Install battery now ! action: format ffs pinout used: (this is why i was not been able to connect) Heres the pinout that connected 1=gnd 6=rx 7=tx |
Unable to format CPU MT6217 | bhogpurmail | Infinity-Box | 12 | 07-27-2008 17:59 |
NEW C550 version & UNABLE TO CONNECT TO PHONE ??? | Genius | UniMoto | 7 | 01-02-2005 12:54 |
MYX1 error while flashing! now unable to connect the phone to the soft??? | AE177 | SagMaster Team OLD Products | 7 | 09-20-2004 21:14 |
LG7050 Unable to connect to phone | msa | Griffin | 8 | 05-04-2004 18:23 |
r320sc unable to connect to mobile network | ranenitin1 | Old Ericsson Phones & Sony Phones | 10 | 07-03-2003 12:22 |
