Old 03-25-2009, 11:06   #1 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
Red face n958gb china problum..pls help
software version: 1.17
cable type: 1x5 (L5A)
platform: MT: MT6208
searching adapter at COM3...
adapter found, version: 2000
pins: 5, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
failed to detect pins
time required: 11 sec
Power Off !
Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") what this? another china working fine.but only L5A cable using time showing like this...pls help
Old 03-25-2009, 11:32   #2 (permalink)
.::MD_AKTER::.'s Avatar
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
pins: 5, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
Here is your pinout
The Following User Says Thank You to .::MD_AKTER::. For This Useful Post:
Old 03-25-2009, 11:37   #3 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
pins: 5, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
Here is your pinout
Old 03-25-2009, 12:22   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
pins: 5, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
Hello,
Are you sure that your phone CPU chip name is MT6208 ?
Old 03-25-2009, 13:03   #5 (permalink)
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
sorry sir, my mobile cpu id MT6225A, but i will check the pinfinde automatic,but still same, same mobile check the spiderman,this software working.but i need format with infinity,only n958gbMT 6225A didnt connect pinfinder&infinity,other all china mobile working fine,pls give the idea or vedio tutorial MT 6225A THANX UR REPLAY
Old 03-25-2009, 21:46   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sorry, i dont get, does other box detected pinout?
Old 03-29-2009, 17:22   #7 (permalink)
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
yes already i did it with spiderman box
Old 03-29-2009, 22:22   #8 (permalink)
Member: 148515
hello!
does phone was able to be powered On from box power?
u9i china phone hanging pls help on wat to do pls macsonugoh Chinese Models & Cloned Phones 2 08-16-2012 17:59
M600 keypad problum pls help nisamknr2@yahoo Sony Ericsson Hardware Repair 3 02-28-2011 12:54
n958gb big problum QADRI Nokia Base Band 5 ( BB-5 ) 0 03-23-2010 06:00
china T98 strang problum...................plzzzzzzz help dilip9714 Chinese Models & Cloned Phones 3 02-28-2009 08:03
how will i kniw what kind of driver my china n95 has?? pls help rhudy_14 Chinese Models & Cloned Phones 3 08-01-2008 06:36
Page generated in 0.42807 seconds with 9 queries
