12-13-2010, 19:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 38
Member: 882614 Status: Offline Sonork: 100.1608795 Thanks Meter: 141 | n96 COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 5 sec Remove/Install battery now ! |
The Following User Says Thank You to reda86 For This Useful Post: |
12-21-2010, 21:01 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. Set activation tries to maximum value "20" press and Hold phone power button and start search. |
N96 | higherzman | Infinity-Box | 11 | 04-02-2009 23:27 |
20 N96 FlashGames | atukhi | Nokia Multimedia | 1 | 01-23-2008 05:56 |
+ OMG: The long awaited Nokia N96 is leaked!!! | apocalypso | Nokia Base Band 5 ( BB-5 ) | 2 | 12-21-2007 14:02 |
need pinout nokia n96 or fake n96 | sevgiesenler | Chinese Cocktail | 1 | 12-11-2007 14:28 |
