n96 one sim double slider hi guys n96 one sim double slider can socket is 5pin like nokia 5610 5310 anyone can help me find pinout?? |
hello! in most cases pinout is not in system connector. i would advice to examinate handsfree port or look for test points on PCB. i can teach how to do this by multimeter (voltage measuring) |
i must read the manual of find pinout with voltage measuring? or other solution? |
hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
thanx for ure help i found the pinouts and i will get a image and upload it for other guys really thanx!! |
hello! we will wait your pinout picture for adding to our pinout collection. Thank you in advance! |
1 Attachment(s) here is the pinouttttttttttttttttttttttttt |
hello! thank you very much! will be inculeded to out collection |
1 Attachment(s) this another model for n96 :cool:ok rx tx in left or rigt ok |
thank you very much for your help!!! |
2 Attachment(s) Somebody have pinout for this ver.?? |
Did anyone find the pinout ? Thanx ! |
I removed the processor but I don't know which are Rx and Tx . |
And the winners are : |
1 Attachment(s) And the winners are : |
