03-06-2008, 15:28 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 44
Member: 70206 Status: Offline Sonork: 100.1616268 Thanks Meter: 27 | n96i rstart after iert sim card problem i cant conect cabe with n96i 1:rx 2;tx 6;gnd plz help i want corct plan for n96i thanks for replay |
03-06-2008, 15:30 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
03-06-2008, 16:44 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @ahmed nokia YOUR information can help YOU to help YOU because YOU have YOUR phone on hands but not me ! Please, read again this instruction: http://67.15.194.130/vbb/showpost.ph...37&postcount=2 |
03-06-2008, 17:15 | #5 (permalink) |
Member: 70206 Status: Offline Sonork: 100.1616268 Thanks Meter: 27 | thanks 4 replay iam find it pin 4 tx pin 5 rx pin 6 gnd i have too phone 1 format ok and done and anther thanks i repear on phone but anther i have white screen i read flash in firest phone and writ in sc no repear |
03-06-2008, 17:25 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Infinity-Box "Chinese Miracle": How to repair "White LCD", "Black LCD", "no LCD" problems: 1. check phone hardware: LCD unit may be damaged. 2. check phone hardware: LCD flex cable may be damaged. 3. use other flash files for flashing, because exist many different phones with different LCD hardware types so need to use different firmware files and find firmware that work good for your LCD hardware. Select flash file with similar firmware version, phone model name is not important, only firmware version is important. |
V9 unlock successful test card use ok but gsm sim card problem | rokon | Motorola P2k | 0 | 01-11-2010 17:53 |
Sim card problem, only reads 64k sim cards | nost | Nokia Hardware & Hardware Repair | 4 | 08-20-2009 01:22 |
SIM Card problem after WM2003 error | nestul | HTC & Smartphones ( WM Without Touch) | 1 | 11-03-2008 22:06 |
6230 insert sim card problem after rehot | sandokaan | Nokia Hardware & Hardware Repair | 9 | 04-22-2007 10:18 |
Urgent:16c after unlock Sim card Error:HEELP | GreEn | Alcatel & TCL Old Models | 5 | 06-21-2000 19:10 |
