02-09-2010, 17:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | N97 need help I NEED HELP WITH N97 .. I HAVE 5pcs with me and although i have changed the language to English not everything comes in English there are many applications that are in only chinese .. I used *#0044# send and it accepts and says changed to English language i have read the log but i need to know which is the appropriate file i can flash with cause i dont wanna kill anyone of these phones ,, please help me here is the log: COM13 [VCP9] selected module v3.06 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001803:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2.BIN project-id: MAUI.08B.W08.52.MP.V22.F2, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF detecting ffs/eeprom structure pass 1... ................................ detect standard ffs/eeprom location pass #1... .................................................. ........... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F detecting firmware build... .................................................. ........... firmware build: 200912111554 detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. . language parameters detected detected languages: En Cn Cn sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 1 min 46 sec Remove/Install battery now ! thanks Mike |
02-09-2010, 21:12 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup (read full flash on speed 921600) and download same version flash file from support. here is example how to find correct file: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 |
02-10-2010, 11:37 | #3 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Thanks I did search with this file name : NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2 and i got this file name from support Eeeprom and Firmware : eeprom: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2__NOKIA-8800e_ffs_01.B0E.bin firmware: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2__NOKIA-8800e_16m_En_Ru_Id_Tr_Ar.B0M.bin Is this correct ? and should i flash both eeprom and firmware or only firmware to change languages in the N97 app ? I have never flashed a chinese phone so please help me one time and since these are new working phones i dont want to kill them .. I have made full back up of flash file Thanks Mike |
02-10-2010, 11:59 | #4 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | Also regarding above issue i have noted that the firmware i downloaded is Nokia-8800e_16M while the flash ID of N97 reads as flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb Also the size of eeprom file of N97 is 134KB and the size i downloaded is 90.2KB Is this a problem with compatibility or No ? Please answer me so i can go ahead and flash this phone thanks mike |
02-11-2010, 08:32 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! start from writing firmware, do not touch eeprom at the moment make full backup of your existing version (read full flash on speed 921600) save it for emergency case in safe place |
02-11-2010, 10:58 | #9 (permalink) |
Member: 197538 Status: Offline Thanks Meter: 97 | I restored with the original flash and it is working fine ,,, how can i use language pack editor to change this chinese apps to english ... in the same software ? Is there a tutorial ? Thanks Mike |
02-14-2010, 08:44 | #10 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
if you have Lanuguage editor- sure you must use it for language changing. all manuals you can find here: http://www.language-editor.com/ | |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
nokia n97 clone - n97c n00b need help | coreyfrog | Chinese Models & Cloned Phones | 0 | 12-30-2009 23:07 |
i need help for flash n97 cpu:6225 1sim | m_gsm2006 | SpiderMan | 2 | 12-15-2009 09:26 |
Nokia n97 need help | fadisheikh | Phone Unlocking Codes & Maps | 0 | 08-25-2009 23:35 |
