Old 05-28-2008, 09:57   #1 (permalink)
kabirhossain's Avatar
Member: 271880
Sonork: 100.1578866
Thanks Meter: 1,289
Vodafone 226 done but unlock code ?
COM3 [VCP0] selected
Device: Vodafone 226
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
flash chip supported
sw version: EBI_IH_280607_1844 EBI_IH Thhmm Dddmmmyyyy 0123456789ABCDEF DB
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sta_20080528-130609.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sec_20080528-130612.B1E.bin
reading [eeprom-complete]...
file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-complete_20080528-130614.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 40 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
Enter code: 12345678>
wrong code 16135 mins later you may retry.
please help how to do ?
Old 05-28-2008, 10:19   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,184
full flash with repiar file than try to unlock.....
Old 05-28-2008, 13:10   #3 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
no need u jesy unlock again and put sim card in phone and leave it for 20 min try to put code i done many phones by this mathod
and hope this will work for u all so
good luck
Old 05-28-2008, 15:45   #4 (permalink)
Emmanuel Ankah's Avatar
Member: 167261
Thanks Meter: 19
if network code can it be done with furious gold. l have done may times not at all
Old 05-28-2008, 15:58   #5 (permalink)
Member: 167261
Thanks Meter: 19
good luck
how 20 min for net code? vodafon
Old 05-28-2008, 16:00   #6 (permalink)
Member: 167261
Thanks Meter: 19
solutoin for failed imei damage vodafone
Old 05-28-2008, 16:01   #7 (permalink)
Member: 65039
Thanks Meter: 13
If is wrong code "12345678", you tray to enter "00000000". I just have made unlock on 2 pieces.
Regards,
Old 05-28-2008, 16:13   #8 (permalink)
Member: 167261
Thanks Meter: 19
Regards,
how did you do it ?imei damage after writing erom to fon
Old 05-28-2008, 16:27   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Dear Boys,
Some messages was deleted in current thread as offtopic.
Please, if you want to discuss about other products, write your messages in other forum sections.
Here is Infinity-Box support forum so let's talk here about Infinity-Box !
Thank you very much for your kind understanding !
Hope now you understand where to write your messgaes !
sfr unlock done but still code request AYAZ42 FuriousGold 1 02-15-2010 13:43
vodafone 226 by sagem unlock 100%by infinity box genci titi 2002 Infinity-Box 2 08-21-2008 13:14
vodafone 226 fm sp unlock rajendrakumar Infinity-Box 6 08-14-2008 08:30
Page generated in 0.22743 seconds with 9 queries
