06-28-2006, 11:52 | #1 (permalink) |
Registered User Join Date: Apr 2002 Location: in a cozy place
Member: 10672 Status: Offline Thanks Meter: 7 | nec 343i COM1 selected Device: Nec N343i Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Skip: Map/Customization Skip: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22212200 Flash: 98E59F00000000 Boot Done Set baud... slowest Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Err: wrong answer[] Err: write[03]: 01010000 Retrying... Err: wrong answer[] Err: write[03]: 01010000 Retrying... please help |
06-28-2006, 23:24 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, There is a little difference in "unlock" and "flash". Anyway, I think you have a reason to make this: 1. charge battery and try again 2. download latest QModule from support area and try again 3. if not helps: check hardware |
07-12-2006, 17:28 | #3 (permalink) |
Insane Poster Join Date: Nov 2003 Location: Burgos (Spain) Age: 47
Member: 44029 Status: Offline Thanks Meter: 2 | I have same problem, but when soft try and try to get an asnwer, I press "stop " button and soft show me finished, write down, Phone now is unlocked... Itīs hard to understand, maybe a bug in software? Regards |
codes Siemens Cl75, Nec 343i, Toshiba TS10, NEC e121, Panasonic SC3 | hottt388 | NEC | 1 | 01-20-2008 18:12 |
FREE update for unlock by IMEI for ALL: NEC 343i, NEC E121 and Siemens CL75 | Multi-COM | GSM Mobile Links | 3 | 06-02-2006 08:08 |
Unlock NEC 343i? | londocdoc | NEC | 58 | 11-28-2005 21:05 |
unlocking NEC 411i / NEC 343i | derekh37 | Infinity-Box | 0 | 11-01-2005 11:22 |
