Nec 343i freeze in log O2 i flash eeprom i do full flash .reset settings,unlock the same situation COM18 selected Device: Nec N343i Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22212200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Write: Map/Customization area requested/selected: 01/01 area requested/selected: 01/01 area requested/selected: 02/02 Write: Language Pack area requested/selected: 01/01 Write Done Finished Remove/Install battery now ! Time used: 51 sec what else can i do |
Hi, If you have made all above mentioned operations but phone still in the same old condition it can be hw problem, f.e. water. |
check your phone hw remove battry backup & see |
try this try to reset phone without sim card ... |
Forious Gold it is solution Full flash repair and after unlock My phone is alive now Anyway thx for reply |
