01-25-2007, 11:19 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Nec 343i freeze in log O2 i do full flash .reset settings,unlock the same situation COM18 selected Device: Nec N343i Checking data, wait... Action: Flash write "SmartWrite" enabled Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22212200 Flash: 98E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Write: Map/Customization area requested/selected: 01/01 area requested/selected: 01/01 area requested/selected: 02/02 Write: Language Pack area requested/selected: 01/01 Write Done Finished Remove/Install battery now ! Time used: 51 sec what else can i do |
codes Siemens Cl75, Nec 343i, Toshiba TS10, NEC e121, Panasonic SC3 | hottt388 | NEC | 1 | 01-20-2008 18:12 |
nec 343i camera freezes | nellabe | NEC | 0 | 09-30-2007 19:27 |
FREE update for unlock by IMEI for ALL: NEC 343i, NEC E121 and Siemens CL75 | Multi-COM | GSM Mobile Links | 3 | 06-02-2006 08:08 |
unlocking NEC 411i / NEC 343i | derekh37 | Infinity-Box | 0 | 11-01-2005 11:22 |
