nec e101 need help! after flash whis russan and unlock nec e101 imea became 0000000p0000000 i try to use repair imea option but still the same. pls help! |
Hi, Pls, send me Log file to mail: [email protected] Also, try to flash with E101 firmware 0.63 and check what's happen with Imei. |
i send u 2 logs 1st from latest soft second from 1.20. now i try to flash whis cheneese flash file but it wasnt chineese phone but europe probably from italy but it have strange colour black. |
Hi, And how about Imei after 0.63 ? |
nothing help! Parameters Done Check Boot block... Check Boot block Done Check space... Check space Done Check Flash-1... FLASH[3D0006]: 01:227E Check Flash-1 Done Check Flash-2... Check Flash-2 Done Check Flash-3... Old Imei: 410524054472009 Wait... Err: New Imei is the same as Old Imei Err: Operation aborted Check Flash-3 Fail Finished Remove/Install battery now ! Time used: 46 sec and 1st quiestion is why it read such imea when on display is 04000pp00000000 2nd original imea begins from 3544720091 and writen begins 410524054? pls help its realy urgent :( my icq 148638372 |
phone is originaly locked 2 tim :( customer is realy mad on me pls hurry. |
try change to 00000000000 and then original. try other flash files |
000000000000000000000000000000000 |
if u use this sof u must 2 know that it not alowed to use any imea but only from popup and it in any case cannot write original :( |
infinity support where r u? |
Hi, Really, I have no any good answer now. Thinking what to do. It can be that this problem is similar with old problem with A100 imei. Problem can be: after firmware downgrade phone can't detect real imei due to old firmware can't work with new phone HW good. Please, check again Imei after flashing with 0.63 firmware. What is Imei value after flashing with 0.63 firmware ? Also, now we are looking for newest E101 firmware for new test. |
whis 0.63 is the same prob |
any news i think i should buy this phone :( |
i have the same phone 050903n-08.00 RK1KEN-0.49D DTCW-VAR after downgrade to ver 44 phone imea corupted i just flash it. but now i have original backup does it help u? its realy urgent. |
Hi, Yes, this can helps. Pls, send readed flash to: [email protected] We will test it and upload it into Infinity-Box support area ASAP. |
