Old 10-21-2005, 16:54   #1 (permalink)
Member: 76522
Thanks Meter: 30
Lightbulb nec e101 need help!
after flash whis russan and unlock nec e101 imea became 0000000p0000000 i try to use repair imea option but still the same. pls help!
Old 10-22-2005, 09:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Pls, send me Log file to mail: [email protected]
Also, try to flash with E101 firmware 0.63 and check what's happen with Imei.
Old 10-24-2005, 07:50   #3 (permalink)
Member: 76522
Thanks Meter: 30
i send u 2 logs 1st from latest soft second from 1.20. now i try to flash whis cheneese flash file but it wasnt chineese phone but europe probably from italy but it have strange colour black.
Old 10-24-2005, 14:03   #4 (permalink)
Member: 130995
Hi,
And how about Imei after 0.63 ?
Old 10-24-2005, 15:27   #5 (permalink)
Member: 76522
Thanks Meter: 30
nothing help!
Parameters Done
Check Boot block...
Check Boot block Done
Check space...
Check space Done
Check Flash-1...
FLASH[3D0006]: 01:227E
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Check Flash-3...
Old Imei: 410524054472009
Wait...
Err: New Imei is the same as Old Imei
Err: Operation aborted
Check Flash-3 Fail
Finished
Remove/Install battery now !
Time used: 46 sec
and 1st quiestion is why it read such imea when on display is 04000pp00000000
2nd original imea begins from 3544720091 and writen begins 410524054?
pls help its realy urgent
my icq 148638372
Old 10-24-2005, 15:27   #6 (permalink)
Member: 76522
Thanks Meter: 30
phone is originaly locked 2 tim customer is realy mad on me pls hurry.
Old 10-24-2005, 15:31   #7 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
try change to 00000000000 and then original. try other flash files
Old 10-24-2005, 15:33   #8 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
000000000000000000000000000000000
Old 10-24-2005, 18:20   #9 (permalink)
Member: 76522
Thanks Meter: 30
if u use this sof u must 2 know that it not alowed to use any imea but only from popup and it in any case cannot write original
Old 10-25-2005, 08:16   #10 (permalink)
Member: 76522
Thanks Meter: 30
infinity support where r u?
Old 10-25-2005, 09:52   #11 (permalink)
Member: 130995
Hi,
Really, I have no any good answer now. Thinking what to do.
It can be that this problem is similar with old problem with A100 imei. Problem can be: after firmware downgrade phone can't detect real imei due to old firmware can't work with new phone HW good.
Please, check again Imei after flashing with 0.63 firmware. What is Imei value after flashing with 0.63 firmware ?
Also, now we are looking for newest E101 firmware for new test.
Old 10-25-2005, 10:29   #12 (permalink)
Member: 76522
Thanks Meter: 30
whis 0.63 is the same prob
Old 11-02-2005, 07:17   #13 (permalink)
Member: 76522
Thanks Meter: 30
any news i think i should buy this phone
Old 11-08-2005, 10:35   #14 (permalink)
Member: 76522
Thanks Meter: 30
i have the same phone
050903n-08.00
RK1KEN-0.49D
DTCW-VAR
after downgrade to ver 44 phone imea corupted i just flash it. but now i have original backup does it help u? its realy urgent.
Old 11-08-2005, 12:27   #15 (permalink)
Member: 130995
Hi,
Yes, this can helps. Pls, send readed flash to: [email protected]
We will test it and upload it into Infinity-Box support area ASAP.
nec N411i need help cooliogsm NEC 0 09-03-2005 16:29
nec 525 need help RRRRR NEC 5 08-30-2005 10:50
Problem with Nec Drivers . Need help ? the_frightener NEC 9 04-15-2005 06:10
nec 331i---need help! garfild FuriouS II 0 02-28-2005 12:06
Page generated in 0.31461 seconds with 9 queries
