06-30-2006, 00:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Italia-Roma Age: 49
Member: 68373 Status: Offline Thanks Meter: 10 | Nec e101 problem...I need help.... What do I have to do for restoring this telephone? Thanks in advance BR Sets the log of the performed operations: RESET SETTINGS: COM28 selected Device: Nec E101 Checking data, wait... Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000032 Flash: 80E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 46 sec UNLOCK: COM28 selected Device: Nec E101 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000032 Flash: 80E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 28 sec UPGRADE FIRMWARE: COM28 selected Device: Nec E101 Checking data, wait... Action: Flash write Write: Firmware Write: Map/Customization Write: Language Pack Skip: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000032 Flash: 80E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Firmware area requested/selected: 01/01 Write: Map/Customization area requested/selected: 01/01 area requested/selected: 01/01 area requested/selected: 02/02 area requested/selected: 02/02 Write: Language Pack area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 1183 sec EEPROM REPAIR: COM28 selected Device: Nec E101 Checking data, wait... Action: Flash write Skip: Firmware Skip: Map/Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000032 Flash: 80E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 area-02... area requested/selected: 02/02 Format file system Done Write... Write: Eeprom area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 55 sec REPAIR IMEI: COM28 selected Device: Nec E101 Checking data, wait... Action: Imei repair Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 98007400000032 Flash: 80E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Old Imei: 354972008230791 Err: New Imei is the same as Old Imei Err: Operation aborted Finished Remove/Install battery now ! Time used: 13 sec |
06-30-2006, 15:46 | #3 (permalink) |
Member: 68373 Status: Offline Thanks Meter: 10 | I have resolved, it depends on the file map brand tim that is found on your support, the map it is not good.... I have inserted a map brand O2 and it now works... change it if you are able BR |
07-29-2006, 23:34 | #4 (permalink) |
Freak Poster Join Date: Apr 2006 Location: colombia Age: 37
Member: 256693 Status: Offline Thanks Meter: 15 | hello my friends sorry my ignorance but i have a nec E101 and dont know what cable use,i try with the cable panasonic A1xx but the phone power on what i do wrong please help me thanks |
07-30-2006, 02:36 | #5 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: Nicaragua
Member: 45752 Status: Offline Thanks Meter: 19 | Quote:
Check in support area "Cables, pinouts" | |
07-30-2006, 09:06 | #6 (permalink) | |
it's need to adjust connector to fit in E101 completely (need to cut rubber around connector metal pin). Check "FAQ" thread and you will see pictures. | |
nec e101 unlock code needed | gazimon | NEC | 4 | 06-24-2008 05:18 |
3200 earpiece VOLUME problem please need help! | adrianbehr | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 06-28-2004 19:36 |
3200 earpiece VOLUME problem please need help! | adrianbehr | Nokia Hardware & Hardware Repair | 1 | 06-28-2004 06:55 |
Strange problem I need help very badly. | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 08-17-2001 01:48 |
Very strange problem.I need help. | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-11-2001 11:32 |
