06-01-2005, 09:41 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | Nec E101 Unlocking Problem |
06-01-2005, 09:55 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: UAE / UK / PAK / HK
Member: 59731 Status: Offline Sonork: 100.99999 Thanks Meter: 514 | HI mate, Infinity works on E101 NEC 100% tested so many times, i hope you using the right cable with the Infinity Box u get, Please use G50 marked cable ! and it shouldnt be any problem also please check your com port settings aswell. it might help. Try and let us know for furthre help. Unlocking Expert Team www.unlockingexpert.com |
06-01-2005, 10:10 | #3 (permalink) |
Member: 59731 Status: Offline Sonork: 100.99999 Thanks Meter: 514 | One more thing mate, i hope that you are plugin in cable on USB side of the box not the SERIAL side of the box. cause it requires fast speed data transfer to unlock it same as flashing G50. but make sure drivers for usb box are also installed. Thanks Unlocking Expert Team www.unlockingexpert.com |
06-05-2005, 01:12 | #5 (permalink) | |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | Quote:
Lets go step by step...... 1- plug in ur dongle .(INSTALL DONGLE DRIVERS FIRST) 2-plug in ur uni box with only usb cable attached to mahcine , ur computer asks for the drivers , the drivers are located in the root directory of ur hard disk partition ,eg:c or d://program files/infinitybox/drivers/cable drivers.wait untill ur machine says - device is ready to use. 3-go to my computer /properties/hardware/device manager/com and lpt settings and see which virtual port is used by infinity usb box. remember the port number . 4- ur box shd be on 5v external supply mode , means on top of the box one light shd be red and one is green. 5- plug in the g50 cable in the left side of the uni box (sivler box) the switch lever shd be on upper side direction. 6-plz note ur g50 cable shd go full inserted into the fone connector ,otherwise cut some rubber at the end of the cable so as the cable jack wd go inside properly. 7- open sw and use the same com port as u have seen in my device manager /com port and lpt settings. 8- press unlock and wait untill it asks u to power on the fone , ur fone boots up and is unlocked after 15-----20 sec. Note: if ur fone does not communicate with sw , try to reduce the baud rate from sw - decrease it to make it stable. works fine. REGARDS GOHAR | |
06-10-2005, 11:53 | #8 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Hi I am havoing problem unlockin E101 and get the following: Checking data, wait... Boot... Press Power button now ! Connecting, wait... Boot Done Parameters... Parameters Done Check Boot block... Err: wrong answer: 15 Check Boot block Done Check space... Check space Done Check Flash-1... Check Flash-1 Fail Finished Remove/Install battery now ! Time used: 21 sec Checking data, wait... Boot... Press Power button now ! Connecting, wait... Boot Done Parameters... Parameters Done Check Boot block... Err: wrong answer: 15 Check Boot block Done Check space... Check space Done Check Flash-1... FLASH: 98:0074 Check Flash-1 Done Check Flash-2... Err: wrong answer: Err: Flash chip problem ! Check Flash-2 Fail Finished Remove/Install battery now ! Time used: 23 sec Any ideas whats gon wrong please. br msa |
06-10-2005, 17:43 | #9 (permalink) | |
Please, be sure that you use latest E101 software: Nec_E101_v120 Please, try to make several other unlock attempts and send to us Log file (InfinityHelp at yahoo.com.hk). It looks like error take place in different stages, so we need to get more info. Also, is it your first E101 or you already have unlocked other E101 before ? If it's first phone, then pls be sure that connector completely inside phone. B.R. InfinitySupport | |
06-10-2005, 18:13 | #11 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Thanks for the replies. Yes it is my first phone I am trying to unlock. The customer would not wait so I will have to wait for another phone to try. I was using V1.20. I had to pull the connect out a bit (1.0-1.5mm) for phone to coonect. When I pressed the connector fully into phone socket it did not recognised the phone. Is this normal?. Thanks br msa |
06-10-2005, 21:50 | #13 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: ...where eagles fly...
Member: 19267 Status: Offline Thanks Meter: 101 | Quote:
fren u can do it ... 1. CUT THE RUBBER AROUND THE EDGE OF THE G50 CABLE CONNECTOR A LITTLE 2. FIRMLY INSERT THE CABLE INTO THE HANDSFREE CONNECTOR OF PHONE 3. CONNECT TO YOUR INFINITY BOX OR USE YOUR UNI BOX WITH INFINITY CABLE AND CONNECT THE 5v POWER 4. CLICK UNLOCK NOT: IF PHONE NOT DETECTED TRY REMOVING AND INSERTING AGAIN AND HOLD FIRMLY GENTLY TURNING THE JACK PLUG IN THE PHONE CONNECTOR BET there shoul;d be positive result.... wish you unlocking till INFINITY...... @damabib @hurricane | |
06-17-2005, 21:29 | #14 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Well bugger me, I manage to unlock one today after 4hrs of playing. Mine turned out be opposite to every one else it seems. I had to pull the cable out about 1.5mm and reduce the speed to very low (never notice the speed slider untill I read the post above agian ) ie. about 3mm away from extream left. But I did it . Thanks msa |
NEC e101 unlock code-can you help a damsel in distress? | ritametermaid | Phone Unlocking Codes & Maps | 3 | 12-15-2005 16:42 |
nec e101 unlock code | Siemens man | FuriouS II | 3 | 10-11-2005 18:43 |
Nec E101 Unlock | Mansoor | Infinity-Box | 2 | 06-28-2005 13:08 |
Nec E101 unlock | filipas | NEC | 23 | 05-09-2005 18:41 |
nec e101 unlock | whiteribbon | NEC | 30 | 03-15-2005 01:48 |
