Old 09-05-2005, 20:18   #1 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 225
Nec E101 won't connect with infinity
Hi infinity team
i have here one nec E101 that won't connect after many try with power switch somtimes i get this
Press Power button now !
Connecting, wait...
Err: wrong answer1[]
Boot Fail
Finished
Remove/Install battery now !
Time used: 91 sec
the phone is from O2 the cable is working 100% tested with other phones i have
also checked phone jack from inside with multimeter all seems good and test also serial activity with comreader communication is good as i can see ATR from phone when powering on
regards
Old 09-05-2005, 21:40   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,226
Hello,
I am sure that it's problem with cable. Pls, try to cut plastic around metal pin more to be sure that connector is completely inside phone. This can helps. Really, I don't have any other idea than cable problem.
Old 09-05-2005, 21:45   #3 (permalink)
HONEY's Avatar
Member: 44158
Sonork: 100.64344
Thanks Meter: 143
I also got same problem then i take that cable out a little from phone's connector and it got connected, also try this.
BR.
Old 09-05-2005, 21:57   #4 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 225
Originally Posted by InfinitySupport
Hello,
i have cut plastic around the metal jack already before posting here and it's not cable problem
do these phone have all same booting algo that what we need to know
regards
Old 01-26-2009, 16:39   #5 (permalink)
Member: 710426
I also same problem my cable have not plastic deep and it metal which cannot cut I try also cable come with padfinder but still not connect so I direct sold cable but still not work. anyone have solution? problem is SIM MEP lock failed. Waiting for your kind response.
Kind regards,
Vicky
Old 01-26-2009, 17:04   #6 (permalink)
Member: 130995
Hello,
Are you sure that you have use 4-pins hands-free cable ?
If you tried to solder wires to PCB and still no luck you can try to swap RX <-> Tx wires
china nokia-1112 not connected with infinity /\/\A/\/| Infinity-Box 9 05-21-2009 08:06
china nokia-1112 not connected with infinity /\/\A/\/| Infinity-Box 3 05-19-2009 21:35
ZTE A66 not connecting with infinity box mohammed ako Infinity-Box 5 02-15-2009 14:38
Nec 122 Unlock Sucessfull With Infinity afrar Infinity-Box 5 09-17-2006 15:01
UPDATE: 05 MAY 2005. Nec-E101 Support added to Infinity Box Infinity-Box Infinity-Box 9 05-05-2005 21:54
Page generated in 0.30465 seconds with 8 queries
