12-02-2005, 18:35 | #19 (permalink) | |
Crazy Poster Join Date: Jul 2005 Age: 44
Member: 164812 Status: Offline Thanks Meter: 0 | Quote:
how to open the phone and how to connect the 3210 cable?? thx | |
12-02-2005, 19:22 | #20 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Behind Enemies Lines;)@Jungle Age: 44
Member: 58608 Status: Offline Sonork: 100.87163 Thanks Meter: 54 | to all u can use old cable test for nec 808 -606 .it can help u to unlock your phone . if u don't have this cable u can use sagem cable 9xx from universal this cable have same tx-rx-gnd wbr BAYOO |
12-10-2005, 11:17 | #23 (permalink) |
Junior Member Join Date: Jul 2003
Member: 33604 Status: Offline Thanks Meter: 5 | nec 343i powers on using d500 handfree connector help?? i am using d500 phf and connected rx tx ground but does not correspond phone power on please advice? sagem cable black blue and white blk gnd and white rx blue tx ? is it right i have also swapped white and blue help?? |
12-20-2005, 12:29 | #24 (permalink) |
No Life Poster Join Date: Mar 2002 Age: 45
Member: 10483 Status: Offline Thanks Meter: 23 | I did it, but always the same problem : COM1 selected Device: N343i Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Err: Boot failed: 3B Release Power button ! Err: wrong answer1 Boot Fail Finished Remove/Install battery now ! Time used: 4 sec |
01-08-2006, 07:51 | #25 (permalink) |
Freak Poster Join Date: Jul 2005 Location: E N G L A N D Age: 41
Member: 163474 Status: Offline Thanks Meter: 138 | i have the nec343 i cable, i buy it from lisi comunication, china my cable is good, but its not unlocked. bad software, infinity cannot unlock 343i..... b.r |
01-08-2006, 09:46 | #26 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
01-08-2006, 15:51 | #27 (permalink) | |
How did you tested cable ? If you really have problems with unlock, pls, post here Log file. It will be interesting to see what is wrong (if it's really wrong but not just simple problem with your cable) | |
01-11-2006, 13:40 | #28 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | incase someone wish to unlock a 343 using infinity, here is my bad experience for your warning... i use test point head from philips cable kit and connect the correct pins through holes under antenna cover. this dont work... i strip apart phone (not easy) and solder these wire direct. dont work.... i try with serial powered and non powered cables dont work.... i take an RJ45 cable and cut off phone connector. now using thunderstorm serial port emulator and its pin outs, i again solder correct wires to the test points. guess what? dont work... so i give up and try to reassemble phone. fúckin keypad is now not responding in some keys due to its shít design... best wait for correct cable... |
01-15-2006, 17:30 | #29 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: england Age: 65
Member: 24552 Status: Offline Thanks Meter: 13 | Quote:
Also motorola c350 connector works if it has ten pins i have spare chargers from nec but not enough pins inside . | |
01-15-2006, 22:07 | #30 (permalink) |
Freak Poster Join Date: Feb 2005 Location: on earth
Member: 120740 Status: Offline Thanks Meter: 3 | no need to open phone just open back cover you need a com cable ... any old very easy just use vk207i com cable . u can find there three wire red rx green grn and white tx ...................... COM1 selected Device: Nec N343i Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 01227E22212200 Flash: 98E59F00000000 method: 02 Boot Done Set baud... Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... method: 02 method: 01 Writing Done Finished Remove/Install battery now ! Time used: 169 sec |
Help For Unlocking Nec N343i | Mobile Master Pk | NEC | 16 | 01-14-2011 06:15 |
NEC N343i find pinout successful | pethu | PadFinder box | 0 | 07-22-2009 09:11 |
@Hack3r2k nec n343i unlocked?? | Siemens man | FuriouS II | 33 | 11-29-2005 19:19 |
Nec-N343i unlock: looking for beta-testers | InfinitySupport | Infinity-Box | 20 | 11-21-2005 15:40 |
