ned help have lg kp100 from relince to unlock 300 pec. but its new security ned help have lg kp100 from relince to unlock 300 pec. but its new security here is read info logs Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KP100FL-01-V10d-404-83-SEP-30-2008+0 imei: 35588202430011500 Done Finished here is backup eprom logs COM4 [VCP2] selected module v1.73 Device: LG-KP100 Checking data, wait... Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20110203-121811.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_20110203-121811.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_20110203-121813.B1E.bin backup critical area Done Check memory ... completed Finished, time used: 19 sec Remove/Install battery now ! here is unlock logs COM4 [VCP1] selected module v1.73 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20110203-114536.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_20110203-114536.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_20110203-114537.B1E.bin backup critical area Done Check memory ... loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 error: can't read codes Finished, time used: 21 sec Remove/Install battery now ! here is link of flesh file with eprom read with infinity box http://www.mediafire.com/?74atwabu14o0tru |
Friend, Have you tried this method- Flash with this file- KP100-04-FL-49-V10a_262-07_FEB-12-2008+2_En_De_Es_Fr_firmware_lp.B1M.bin Then read unlock code and then insert any sim and enter code. Don't forget to take full backup first. Post result. Wr. |
@joni_rajpura 1. make full flash backup for emergency case 2. unlock phone with "method #2" What is the results ? |
unlock phone with "method #2" not working sir |
please post here log do u get the same error with method 1 that u got with method 2 we can help you unlock your phones, but you have to help us with accurate and detailed feedback |
COM4 [VCP2] selected module v1.73 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" direct unlock method #1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20110203-123433.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_20110203-123433.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_20110203-123435.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000040 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000040 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000040 instead of 000001DA error: operation terminated [00FF] loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 error: can't read codes error: not locked or unknown eeprom Check memory Failed Finished, time used: 21 sec Remove/Install battery now ! |
COM4 [VCP2] selected module v1.73 Device: LG-KP100 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20110203-123500.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.0 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_20110203-123500.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_20110203-123502.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 14 sec but still locked |
where r supporters ................... |
Did you tried to flash phone with another firmware from support area ? What is the results ? |
