03-20-2010, 09:03 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: India
Member: 690799 Status: Offline Thanks Meter: 157 | Lg Kp320 , hang on "kp320" logo on lcd screen. is this software problem or hardware : Lg Kp320 , hang on "kp320" logo on lcd screen. I have tried with software wit diff. flash file given on support area. here is soft. log ; COM1 [VCP0] selected module v3.23 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10e-404-XX-APR-18-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2K_En_Hindi.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (general #0)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #1)... not required nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2K.bin nfi area detection finished: Ok "format ffs" active interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610IN00-001-R2K detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2K.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2K.BIN project-id: 7S7610IN00-001-R2K, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2K.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 1 min 42 sec Remove/Install battery now ! |
03-20-2010, 16:48 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to make "format ffs" in "complete" mode. Also, be sure that you have at least 128 Mb free space at your HDD, this helps to avoid problems with flashing. |
03-21-2010, 10:01 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You must repair phone hardware ! If somebody drop something on the floor it is impossible to damage phone software but it's possible to damage hardware only. so you must open phone and check it's hardware, f.e. rehot/reball CPU and flash chip etc. |
03-21-2010, 10:01 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Same answer for the same problem: http://forum.gsmhosting.com/vbb/5603031-post6.html |
U600 hang on samsung logo on start up, done.. | fonERICKS | Z3X-Team Products | 2 | 02-10-2014 16:41 |
Lg u880 hangs with 3 logo | Unicom | LG | 0 | 03-24-2010 07:53 |
m200 hang on m200 logo on screen | rohit50 | NSPRO | 5 | 07-23-2009 11:38 |
LG U880 hang with 3 logo | Unicom | LG | 4 | 01-01-2009 13:44 |
LG U880c hang in 3G Logo | ASHRIFF | LG | 1 | 03-03-2007 01:23 |
