12-08-2009, 18:11 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
12-14-2009, 16:49 | #8 (permalink) | |
Freak Poster Join Date: May 2008
Member: 778346 Status: Offline Thanks Meter: 34 | Quote:
Ajanta a1900 its mean its not supported | |
12-16-2009, 13:20 | #12 (permalink) | |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | Quote:
Here Goes the Pinout. Code: software version: 1.19 cable type: 1x12 (L12C) platform: PMB: Infineon e-gold searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold: 820000 result: Rx:7 Tx:6 time required: 22 sec Trying to Power-On... Power On ! Power Off ! Power On ! Power On ! saved: Ajanta-A1900 Hoping to see this Phone soon on Support.. Regards Shubhanshu | |
The Following User Says Thank You to Shubhanshu~ For This Useful Post: |
Ajanta a1900 limited service?????? | omkarvitekar | Infinity-Box | 5 | 04-24-2010 15:23 |
Ajanta A1900 Insert sim before Repair IMEI | rajkamal_kasdol | Infinity-Box | 2 | 03-09-2010 06:16 |
ajanta a1900 pinout here | sonumobilewala | Infinity-Box | 1 | 03-04-2010 12:14 |
Urgently need Ajanta A1800 pinout!!! | ..::MOBILES::.. | Infinity-Box | 10 | 01-08-2010 05:08 |
Ajanta A1900,A2100,A3000,A5000 flasher | Vijendra Saini | Various | 9 | 12-16-2009 11:58 |
