04-20-2010, 13:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Need a big help - motorola WX288 I need a big help for this phones. I like to put horvatski lenguage to many phone. I have in hands 2 phone the first have horvatski language here: RapidShare: 1-CLICK Web hosting - Easy Filehosting and the other that not have. here: RapidShare: 1-CLICK Web hosting - Easy Filehosting I tried read firmware and put into the other one but phone not turns on. Than i readed the two phones fullflash and uploaded to rapidshare. Is it possible to get help ASAP? Many thanx DaZexy |
The Following User Says Thank You to dazexy For This Useful Post: |
04-23-2010, 12:13 | #3 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | wx288 not accept update Quote:
Many thanx for quick move. A downloaded the prepared files i sent to soupport, but after write the firmware still cant finalize the phone, so phone wont power on after flash process. Here is the log: COM15 [VCP1] selected module v3.35 Device: Motorola-WX288 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware M288X-2AVDHU1-166_XT16HT13_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2010-01-15_En_Tr_Sh_Sl.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BEDA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D1473 220.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_785EE485].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D1473220 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 85E45E78 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: M288X-2AVDHU1 customization: CT16HT13 customization: XT16HT13 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35668303144534 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.D1473220.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_F856B7B1].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.D1473220._JRD23_08A_P CB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_F 856B7B1_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.D1473 220.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_F856B7B1].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.D1473 220._JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9.BIN_F856B7B1_.rpl ==================== warning: unknown rom info structure: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_F856B7B1 Unknown firmware detected (v.3.35, database date: 22.04.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_785EE485_20100423-123857.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CT16HD13 customization name adjusted customization: CT16HD13 customization name adjusted customization detected: CT16HD13 customization: CT16HD13 customization: XT16HT13 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->086B02A8 ..................region counter set: 01 security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_785EE485_20100423-131311.B0X.bin Finished, time used: 38 min 2 sec Remove/Install battery now ! | |
04-23-2010, 12:32 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Updates software just uploaded in "main" support area mirror (with new firmware types support), MModule v3.36 Download it and try to use it. Waiting for your results. |
04-23-2010, 14:43 | #5 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | wx288 Quote:
I try this version. Everything looks fine. afer flash process the phone stay some seconds on motorola logo screen than shout down. i tired format in safe mode. Here is the log: COM15 [VCP4] selected module v3.36 Action: reset settings ("format ffs") Model: Motorola-WX288 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BEDA:A00C status: 01 Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: 4Νόľ˛23,Ĺ05 Date: 200°.°°ż00 Version: ±.0 Version: ΝΑύΙľ08PιΒr˛rĂĹs˛ď0`Ŕ Version: Ęϊδ˛ł_0ĽP ˙0`Ŕ 80 byte(s) read warning: wrong packet cs warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 1 min 57 sec Remove/Install battery now ! Now i upload the fubu i made and waiting for fixes... Many thanx for help!!! Dazexy | |
04-23-2010, 15:08 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If phone was simlocked try to make this: 1. use "Write" button from software "Service" page and write original imei (from phone back label) 2. make "sp-unlock" |
04-23-2010, 15:08 | #7 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | here is the operation log (FUBU restore): in this case phone works fine: COM15 [VCP4] selected module v3.36 Device: Motorola-WX288 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs NH_Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__fullflash_part_1_of_1_20100420-130419.B0M ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BEDA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D1473 220.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_F856B7B1].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D1473220 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, B1B756F8 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: M288X-2AVDHU1 customization: CT16HT13 customization: XT16HT13 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35668303144534 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_F856B7B1_20100423-154504.B0X.bin Area: Eeprom/ffs flash: 98000300000001:2BEA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CT16HT13 customization name adjusted customization: CT16HT13 customization name adjusted customization detected: CT16HT13 customization: CT16HT13 flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... use default security area (sec info, hash) pattern error: can't assign default hash address range for offset: 00000000/00001000 error: security area (sec info, hash) size is too small: 0000 error: can't calculate security area (sec info, hash) Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_F856B7B1_20100423-155255.B0X.bin Finished, time used: 9 min 33 sec Remove/Install battery now ! and here is the log (new firmware upload, change languge): after this operation phone starts and shows motorola logo, and 3-4 sec after that turns off COM15 [VCP4] selected module v3.36 Device: Motorola-WX288 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware M288X-2AVDHU1-166_XT16HT13_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2010-01-15_En_Tr_Sh_Sl.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BEDA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D1473 220.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_785EE485].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D1473220 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 85E45E78 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: M288X-2AVDHU1 customization: CT16HT13 customization: XT16HT13 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35668303144534 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_785EE485_20100423-155655.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CT16HD13 customization name adjusted customization: CT16HD13 customization name adjusted customization detected: CT16HD13 customization: CT16HD13 flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_785EE485_20100423-160506.B0X.bin Finished, time used: 9 min 2 sec Remove/Install battery now ! Many thanx for help! dazexy |
04-23-2010, 16:25 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, send this file to [email protected] C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_F856B7B1_20100423-154504. |
04-23-2010, 16:51 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Also try to make this: 1. go to software "service" page and make "calculate security area" box UN-checked 2. flash phone with your firmware 3. go to software "service" page and make "calculate security area" box checked 4. make "repair security area" operation please, let me know about results |
04-24-2010, 07:13 | #10 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
But on settings page i found: [x] fix security durring flash (if required) Do you tought of this? I will try and post results. I have sent log to mail U gave me. Many thanx: DaZexy | |
04-24-2010, 07:39 | #11 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | thanx finally works Quote:
or have infinity team any multiflasher device? otherwise i need to buy 4-5 more boxes :-) anyway thanx!!! GOOD JOB! i will back after tests! bye DaZexy | |
04-24-2010, 07:40 | #12 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | almost forget... here is the log (security repair) COM15 [VCP0] selected module v3.36 Device: Motorola-WX288 Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BEDA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is damaged, recalculation required rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D1473220 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, B1B756F8 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: M288X-2AVDHU1 customization: CT16HT13 customization: XT16HT13 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: startup code area #1 startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CT16HD13 customization name adjusted customization: CT16HD13 customization name adjusted customization detected: CT16HD13 customization: CT16HD13 flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35668303144534 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX288_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V9__system_log_D1473220_F856B7B1_20100424-082825.B0X.bin Finished, time used: 2 min 47 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! WBR DaZexy |
04-24-2010, 09:39 | #13 (permalink) | |
I think you do not need to use 2 steps for all phones. I think that first phone was damaged during first flash attempt, so we have to repair it in 2 pass. Try to flash other phone as ordinary, I hope it should be Ok. | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
