need blu 5.5k d710 firmware urgent i need blu studio 5.5 k d710 firmware anyone that have this file please upload.here thanks. i have d710 stuck on logo i did format but still stuck i read flash from phone and flash phone but still stuck. ================================================== ====== Card found: S/N 0197:0129 Chinese Miracle II [MTK module] v 1.29 Start at : [9/7/2015 / 10:13:36 PM] Operation : Format FileSystem [ v1.29 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473261110154A39DF8221D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : a2G4 [eMMC] : FLASH_CID : 90014A4834473261110154A39DF8221D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! FMT Mode set to : 0 Format : Cache and UserData (Full Factory Reset) Format CACHE block Format block Ok! Format UDA block Format block Ok! Done! Elapsed: 00:00:53 Reconnect Power/Cable! Finish at : [9/7/2015 / 10:14:29 PM] ========================= Start ========================= 9/7/2015 / 10:20:26 PM ================================================== ======= Card found: S/N 0197:0129 Chinese Miracle II [MTK module] v 1.29 Start at : [9/7/2015 / 10:20:56 PM] Operation : Read Flash [ v1.29 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473261110154A39DF8221D DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : a2G4 [eMMC] : FLASH_CID : 90014A4834473261110154A39DF8221D [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : BLU ProdName : BLU STUDIO 5.5 K ProdModel : BLU STUDIO 5.5 K Device : BLU AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1.7 [Read Ok] : preloader_hexing71_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6571 / V1.1.1 / hexing71_cwet_kk / EMMC FW Size : 673 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6571__BLU__BLU STUDIO 5.5 K__BLU__4.4.2__ALPS.KK1.MP7.V1.7\ All done! Done! Elapsed: 00:16:58 Reconnect Power/Cable! |
did you get blu d710 firmware if yes can you please post a copy |
need it too very urgent |
same here i guess there is no fix for this issue just now |
