04-23-2008, 14:00 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | Need Bluetooth M8800 Flash File Or Eprom File |
05-13-2008, 11:46 | #3 (permalink) |
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | COM21 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:8841:1E60 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.65FE5B13.[GHOST_PCB01_GPRS_MT6226_S01.EV7810_C_JN_V2_7_B01_M .BIN_49174AEC].rpl ==================== New firmware detected: GHOST_PCB01_GPRS_MT6226_S01.EV7810_C_JN_V2_7_B01_M .BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 65FE5B13 identification#1 protocol ver: 04 ver. sw1: GHOST_PCB01_GPRS_MT6226_S01.EV7810_C_JN_V2_7_B01_M .BIN ver. sw2: EV7810_C_JN_V2_7_B01_M, 13B5E8B6 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[GHOST_PCB01_GPRS_MT6226_S01.EV7810_C_JN_V2_7_B01_M .BIN]]... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... warning: wrong cs at 0x00D49C00, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: 90 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? error: wrong answer: F8 Probably errors exist during flash read operation. Do you want to repeat read operation ? warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _65FE5B13_GHOST_PCB01_GPRS_MT6226_S01.EV7810_C_JN_ V2_7_B01_M.BIN_49174AEC_20080513-160419.B0X.bin Finished, time used: 1509 sec Remove/Install battery now ! |
05-13-2008, 19:43 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please check if your phone battery is fully charged, repeat operation. if you still fail to read out backup- i would adice to heat or resolder flash IC |
Need Bluetooth Zt8866 Flash Files....... | sahil00150 | Chinese Models & Cloned Phones | 3 | 04-07-2009 14:35 |
Need Bluetooth LV530 flash file | joggaboy | Chinese Models & Cloned Phones | 0 | 01-22-2009 05:41 |
Need 6300 Flash File & Eprom File | sunny_gsm | Infinity-Box | 1 | 08-02-2008 11:31 |
Need K550 Full Flash File Or Gdfs File | haider | DreamBox | 1 | 07-03-2008 13:43 |
I Need T400 Eprom File Or UST File | Mahmudul | VLSI, Conexant, Skyworks and Old Models | 4 | 09-12-2003 22:54 |
