06-22-2008, 17:21 | #3 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Nigeria
Member: 218859 Status: Offline Thanks Meter: 2 | [quote=farhanali;3417853]pic for this phone. hope infinty supporters sees this.i have tried more than 10 times with pinfinders to even unlock it.all i observe was that it has spreadtrum chip.hope to hear from them |
06-22-2008, 19:41 | #5 (permalink) |
Insane Poster Join Date: Apr 2005 Location: pakistan,lahore
Member: 141465 Status: Offline Thanks Meter: 6 | pinout software version: 1.10 cable type: 1x18 (L18A) platform: SPD: Spreadtrum SC6600M, SC6600R searching adapter at COM4... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now (not required but recommended) ! detecting pins... Rx:12 result: Rx:12 Tx:13 time required: 57 sec Power On ! my phone do not accept sim card.need format or flash Spreadtrum SC6600M, SC6600R base IC. I think no have suport infinity box for this phone.what i do for this phone.for solve this problem. |
06-22-2008, 20:17 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
hi here is the way 2 make oun chinese miracle cable by hand already tested in 30 to 40 hand set sussesfuly 1st u need com cable of moto C115 cut the pin of moto u will get 3 wire white and blue and black in my cable black is ground and white is RX and blue is TX just open the set and find out the RX and TX there is way 2 find out in set RX and TX just put the charger on TX u will find out 1.7 or 2.7 and on RX u will find out 2.8 or 1.8 voltage or just dounload the latested pinout 4rm fourm mostly nokia set u will find on pcb witten on that so its a easy 2 find out RX and TX and connet on infinity dont make format option first just read full flash and its work perfect then 2 desire option its important 2 find out rx and tx plz make operation veary carefully use it u r oun risk thanks | |
06-24-2008, 14:14 | #7 (permalink) | |
Member: 218859 Status: Offline Thanks Meter: 2 | Quote:
is it cect 1000+ with pinfinder | |
CECT C1000 PINOUT!!!(2sims-2mmc) | bronce | Chinese Models & Cloned Phones | 3 | 06-11-2010 11:34 |
Cect C1000+ Pinout need | Aazib jhon | Infinity-Box | 3 | 06-17-2008 00:41 |
CECT C1000+ pinout | dennis1 | Infinity-Box | 10 | 06-03-2008 07:42 |
Cect c1000 pinout needed | MARK26 | Infinity-Box | 2 | 05-17-2008 19:28 |
