Old 02-04-2008, 16:56   #1 (permalink)
Member: 16700
Thanks Meter: 11
plz guy's i need nckia 5700 pinouts
hi, i want the pinouts of this phones:tx,rx,GND and this phone is 18 pins connector
Old 02-04-2008, 17:13   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
look for marked test points on PCB near bottom of phone
(no need to remove battery)
Old 02-05-2008, 13:58   #3 (permalink)
Member: 16700
Thanks Meter: 11
hi, man i found them but they are many:
GND,RX A,RXB,power,power,TX A,TX B,VBAT
so which TX and RX to take?
Old 02-05-2008, 14:49   #4 (permalink)
Member: 583680
Thanks Meter: 47
@waleedy
for Nckia 5700 10-Rx,12-Tx (in most cases),if not correct try 7-Rx,9-Tx.Use 1 or 18 as ground
http://forum.gsmhosting.com/vbb/atta...9&d=1199644658
Old 02-05-2008, 18:09   #5 (permalink)
Member: 16700
Thanks Meter: 11
but man from the back i found the pinouts on PCB and they are in this order:
GND-RX _A-TX_B-POWER A-POWER B-TX_A-RX_B-VBAT and i'll upload th pic,so which one to take or just go to pin 10 &pin 12 and the GND?
this is the pic:
http://file5.9q9q.net/preview/362374...08031.jpg.html
Old 02-05-2008, 18:38   #6 (permalink)
Member: 583680
Thanks Meter: 47
@waleedy
Rx_A, Tx_A corresponds to CPU1,Rx_B and Tx_B to CPU2,phones Rx attach to box Tx(pin3),phones Tx attach to box Rx(pin2),Gnd to box pins 7,8.
But if You have good working cable (18A) -better use cable and do not demage the phone with soldering iron .I have tested 4 different hardware versions of this phone and each version has pinout directly in the connector.
PS.as Gnd You can use even SIM cards metallic cover or TF card metallic cover.
try and test!
ezzis
Old 02-06-2008, 03:41   #7 (permalink)
Member: 148515
hello ezzis!
thank you for you help
Old 02-06-2008, 13:55   #8 (permalink)
Member: 16700
Thanks Meter: 11
i found them,but now how to find rge tx,rx, on the serial cable
Old 02-06-2008, 20:43   #9 (permalink)
Member: 148515
hello!
you must take needed signals from box Rj45 connector.
box pinout you can find printed on box or in our FAQ section.
i wrote little tutorial how to build own cable step-by-step
http://forum.gsmhosting.com/vbb/showthread.php?t=386780
Nckia 5700+ Bluetooth problem k4runch0 Chinese Models & Cloned Phones 5 09-06-2008 16:33
Heeelp-NCKIA 5700 mikren Chinese Models & Cloned Phones 2 09-05-2008 13:40
plz help i need cect q638 pinout bharat982779950 Chinese Models & Cloned Phones 2 04-23-2008 14:16
urgent i need little hlp with nckia 5700 pinouts waleedy Infinity-Box 6 02-02-2008 19:43
Nckia 5700+ error on imei change TerribleTurk Infinity-Box 3 10-27-2007 10:54
Page generated in 0.15796 seconds with 10 queries
