11-06-2008, 19:32 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Successfull unlock LG-KP100!! COM3 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL O2 KP100 04 FL 49 V10a 262-07 FEB-12-2008 +2 ^ Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081020-111054.B1E.bin loading data... data loaded imei: 35996101776288100 reading [eeprom-sec_35996101776288100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101776288100_20081020-111057.B1E.bin reading [eeprom-complete_35996101776288100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101776288100_20081020-111103.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 57202185 Finished, Remove/Install battery now ! Time used: 23 sec COM3 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL TME KP100 01 FL 34 V10c 214-07 MAR-25-2008 +0 j Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081103-154657.B1E.bin loading data... data loaded imei: 35996101973869900 reading [eeprom-sec_35996101973869900]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_35996101973869900_20081103-154659.B1E.bin reading [eeprom-complete_35996101973869900]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101973869900_20081103-154706.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 75801898 Finished, Remove/Install battery now ! Time used: 23 sec How to enter code: if you have original SIM or motorola test card,power ON phone with it and enter 2945#*20001# goto Menu-Settings-Security-Sim Unlock Code- Desactivate and enter the code you get or read out |
The Following User Says Thank You to Umbabaraumba For This Useful Post: |
11-06-2008, 19:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-06-2008, 19:45 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | Quote:
Hallo! But i think this is since longtime supported by other tool(s)!!?? | |
unlock LG KP100 free with hwk | quinzinho | HWK | 36 | 03-10-2011 03:54 |
I need free unlock LG KP100 | 0leg | LG | 3 | 11-28-2008 02:06 |
can't unlock lg kp100 ::: SOLVED ::: | djouaka | PolarBox 3 | 2 | 11-22-2008 15:08 |
Unlock LG KP100 with HWK | h4mza | HWK | 2 | 10-30-2008 09:53 |
unlock LG kp100 | Handy-Smart.de | SmartKey | 3 | 08-14-2008 21:17 |
