Old 06-05-2011, 16:59   #1 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Need China Anylink N99i flash file?
Phone is working fine but IMEI is invalid I have to rebuild IMEI but not done. I try to format with safe mode not done.. firmware infomation also not showing. I think software is damage... below is logs and phone back side image...
COM3 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
high speed boot On
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E220A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
done
warning: can not detect firmware version
if software freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
done
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En
Finished, time used: 41 sec
Remove/Install battery now !
Old 06-06-2011, 08:15   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this is second (slave) CPU. which IMEI do you need to change? first or second?
try to change IMEI in mode 1 or 2
Old 06-06-2011, 10:21   #3 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
hello!
not done sir
module v3.26
Action: "repair imei"
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 359365005807882
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6205
high speed boot On
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button more long time !
error: operation failed !
Finished, time used: 1 min 17 sec
Old 06-06-2011, 11:28   #4 (permalink)
Member: 148515
hello!
you did not answer which IMEI you need to change. First or second? (SIM A or SIM B IMEI?)
Old 06-07-2011, 17:29   #5 (permalink)
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
hello!
Both are invalid sir I have to change both
Old 06-08-2011, 09:39   #6 (permalink)
Member: 148515
hello!
ok, for SIM B (6205) CPU first of all try mode-3.
if will not work- try mode-2.
please remember that when you booting slave CPU you have to press power button and keep it pressed very long time. up to one minute. do not pay attention if phone will turn On. Just keep button pressed and then second CPU will boot
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.20321 seconds with 10 queries
