02-27-2011, 13:35 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: iSiddeque Age: 41
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Need chinese NOkia N95 8GB RM-51 flash file? I lost software myself by mistake. Phone was working. by mistake I flashed other file set is become dead. I don't have any orginal informat for file. I have only original information this is below firmware date/time: 2010-01-26 12-37 hw1: N95_GEMINI_HW hw2: ÿq·A and i download a file from support area and flashed the phone. after flash phone is on with white lcd. here is the file N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2__N95-8GB_16m_En_Fr_Es_Ml_Id_Vn_Cn.B0M Now I need orginal file for chinese nokia N95 8GB RM-51 please if anybody have upload....? |
02-27-2011, 14:03 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | I have this version- N95-8gb-HX684_GEMINI_07B_HW.YC684_SM2_NT57_B2_NFM_V1_9ETES T--091111.bin try this and post result. Wait for supporter to convert it into Infinity format. Link- N95-8gb-HX684_GEMINI_07B_HW.YC684_SM2_NT57_B2_NFM_V1_9ETES T--091111.bin.7z - 4shared.com - online file sharing and storage - download Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-01-2011, 08:52 | #5 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | here is the logs OM4 [VCP0] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N95-8gb-HX684_GEMINI_07B_HW.YC684_SM2_NT57_B2_NFM_V1_9ETES T--091111.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001303:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent warning: firmware database can not be loaded rom info detection finished rom info ver: 04 sw version: LC6225_GEMINI_PCB01_GPRS_MT6225_S00.LBBKY07_8_12_1 _5T06M0125_M571.BIN project-id: LBBKY07.8.12.1.5T06M0125_M571, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 01227E22212200:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 33 min 50 sec Remove/Install battery now ! |
03-01-2011, 09:15 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Format the set now, first safe and if not works then complete. If still not works need to look for other firmware. Wr. |
03-01-2011, 09:43 | #7 (permalink) |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | sir, I make both formats but not success. this file is working all incoming outgoing but with white lcd here is file N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2__N95-8GB_16m_En_Fr_Es_Ml_Id_Vn_Cn.B0M |
03-01-2011, 13:18 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Wait sometime, I will upload it for you, Only the difference is highlighted. BTW have you searched and tried to flashed with more matching firmwares from support area? Wr | |
03-02-2011, 06:27 | #9 (permalink) | |
Member: 188260 Status: Offline Sonork: 100.1590438 Thanks Meter: 428 | Quote:
03-02-2011, 08:21 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Here is file but wait for supporter to convert it- N95-KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.bin.7z - 4shared.com - online file sharing and storage - download Wr. |
03-02-2011, 12:08 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we have this KCM25 file presented on support server KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12 |
03-03-2011, 09:08 | #14 (permalink) | |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
