Old 11-17-2018, 07:57   #1 (permalink)
Member: 2434148
Thanks Meter: 18
Need DA file for DRA-LX2
hello i need DA file for flashing Y5 PRIME 2018
CANT FIND IT ON NET
PLS IF ANYONE HAVE SHARE IT
Old 11-17-2018, 08:37   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Try connect phone with infinity cm2 v2.02 and post log
Old 11-17-2018, 09:01   #3 (permalink)
Member: 2434148
Thanks Meter: 18
Card found : , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02
Load IDBase v11861 Ok!
Preloader [HW DEV] Info :
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
Operation : Write Flash [ v2.02 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Disabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :22
[FL] : Set : preloader_dura64.bin
[FL] : Set : md1img.img
[FL] : Set : md1dsp.img
[FL] : Set : spmfw.img
[FL] : Set : mcupmfw.img
[FL] : Set : tee.img
[FL] : Set : lk.img
[FL] : Set : lk.img
[FL] : Set : loader_ext.img
[FL] : Set : log.img
[FL] : Set : logo.bin
[FL] : Set : boot.img
[FL] : Set : recovery.img
[FL] : Set : erecovery.img
[FL] : Set : odmdtbo.img
[FL] : Set : cust.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0xB7E2D84C [ 2.87 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM869)
MODE : BOOTROM
PORT : 869
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E3
BROM : SecMode : SBC+SLA+SEL
BROM : BOOTROM
MODE : 0_base : BASE_v1836 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6739
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00000001 : DA SEND ERROR!
ERROR : BROM : DL MODE ERROR
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Old 11-17-2018, 09:42   #4 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Smile
HELLO @zexos; AS PER YOUR LOGS FILE FOR YOUR PHONE TRANSFER TO @JayDi SIR AFTER CORECTION YOU WILL GET IT BACK IF YOU CAN HOLD THE PHONE WILL TRY
GOOD LUCK
Old 11-17-2018, 10:14   #5 (permalink)
Member: 2434148
Thanks Meter: 18
GOOD LUCK
need to send the phone or just keep it to my self
Old 04-11-2019, 14:13   #6 (permalink)
Member: 1834175
Thanks Meter: 52
i have DA :-) , pm
Old 05-29-2019, 12:40   #7 (permalink)
Member: 2502347
Thanks Meter: 4
i want da File Auth File Preloader file for Dra -Lx2 Huwaei how to......?
Old 10-03-2020, 17:06   #8 (permalink)
Member: 2786894
Sonork: YASIR1AMIR
Thanks Meter: 4
sir
i need dra lx2 da file
any one help
Old 10-03-2020, 18:08   #9 (permalink)
Member: 1677653
Thanks Meter: 2,769
Originally Posted by yasir1amir View Post
sir
any one help
put phone to fastboot then try Infinity-Box AST module under fastboot tab or use google search for bypass.
Old 10-03-2020, 19:56   #10 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 408
EMI : DEV :
EMI : SRC :
EMI : CNT : 0000
Files :22
[FL] : Set : lk.img
[FL] : Set : lk.img
MODE : BOOTROM
PORT : 869
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
lx2 da file y5 2018
The Following 4 Users Say Thank You to allttar For This Useful Post:
Old 06-08-2021, 17:04   #11 (permalink)
Member: 2961729
Thanks Meter: 2
lx2 da file y5 2018
thanks bro works like magic
Page generated in 0.17948 seconds with 9 queries
