12-14-2010, 17:43 | #1 (permalink) |
Junior Member Join Date: Apr 2008 Location: vietnam
Member: 744964 Status: Offline Thanks Meter: 3 | Need file 8800e |
The Following User Says Thank You to anhnhan2 For This Useful Post: |
12-14-2010, 21:06 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to search for short version code printed on PCB. this can help a lot usually it is printed under or near LCD |
12-15-2010, 22:03 | #3 (permalink) |
Member: 744964 Status: Offline Thanks Meter: 3 | I cant find any information printed on the PCB, could it have been gone because my hands before the hardware had been repaired several. Phone no power, not boot. Reball cpu 6226ba still not boot, change cpu 6226ba phone boot ok but no power. Read detail infomation i see rominfo of cpu 6233p so it has been changed and i dont know exactly rominfo.Now phone work but no screen, no ring. I'm down on the support of flash test file but Too many files on support |
12-17-2010, 13:56 | #5 (permalink) |
Member: 744964 Status: Offline Thanks Meter: 3 | Phone good working! I do not see any information on the PCB, but i can found short version code by infinity box: COM4 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:FF75:3A34 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN project-id: P02_SP_SSD_NB0_1.2.0TMC1_26B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... ................. ffs/eeprom: detect std location pass #1... .................................................. ...... ffs/eeprom: detect ext location pass #1... .................................................. .. ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B.BIN detecting firmware build... .................................................. .. firmware date/time: 2009-07-16 19-23 hw1: KP26_06B_HW hw2: 05C_H526_05C done detecting product-id... .................................................. .............. done detecting languages... .......................................... language parameters detected detected languages: En Ru Nl Fr De Ml Id Th Vn Tr Farsi Ar Finished, time used: 1 min 51 sec Remove/Install battery now ! I downloaded all the files have H526_05Cxxxxxx and try one by one. Resutl phone good work with file H526_05C_PCB01_GPRS_MT6226_S01.P02_SP_SSD_NB0_1_2_ 0TMC1_26B_build-20090716_16m_En_Ru_Nl_Fr_De_Ml_Id_Th_Vn_Tr_Farsi_A r.B0M.bin! Thanks Infinity! |
12-18-2010, 14:30 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this code is not correct. it belongs to last firmware which you wrote to this phone. can you post same quality picture, PCB front (LCD) side? LCD must be removed |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
