Old 06-08-2019, 18:21   #1 (permalink)
Member: 496839
Thanks Meter: 14
need file Da acer iconia a1-810
need file da tablette acer iconia a1-810
logo
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM6)
MODE : PRELOADER PORT
PORT : 6
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6583 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1812 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
Old 06-08-2019, 18:24   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,656
MT6589 can be found in v17xx base line.
Old 06-08-2019, 18:34   #3 (permalink)
Member: 496839
Thanks Meter: 14
not found
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : Found MT6583
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : Connect device in BROM mode!
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : 0_base : BASE_v1724 | Manual : Enabled
Old 06-08-2019, 18:36   #4 (permalink)
JayDi's Avatar
Member: 462970
SW clearly wrote what you must do to connect it. Follow software logs. Read them.
Old 06-08-2019, 18:49   #5 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,305
in BASE_v1712 select DA_SWSEC.bin not MTK_AllInOne_DA.bin
or try to boot in brom mode with vol+ vol- keys by select MTK_AllInOne_DA.bin
and post result here
Old 06-08-2019, 21:24   #6 (permalink)
Member: 496839
Thanks Meter: 14
not work the select DA_SWSEC.bin
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
AGENT : DA_SWSEC.bin
Old 06-08-2019, 21:35   #7 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,305
how about brom mode with vol+ vol- keys by select MTK_AllInOne_DA.bin ?
Old 06-08-2019, 21:37   #8 (permalink)
Member: 2812901
Thanks Meter: 375
Hold both volume button !!! brother.
Old 06-10-2019, 16:52   #9 (permalink)
Member: 496839
Thanks Meter: 14
with brom mode does not function I hold both volume buttons
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
Old 06-10-2019, 17:26   #10 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,305
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
try with this DA
https://mega.nz/#!3P4HHAYC!FbwQu1MzK...j70tnjEmoI-nNM
Old 06-10-2019, 20:41   #11 (permalink)
Member: 496839
Thanks Meter: 14
with this DA does not finish the boot
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : OK
NAND : 000000000000000000000000
eMMC : OK
eMMC : 00000000000000000000000000000000
DAInf: 0 : 0 : 0
DA : EXT_RAM NOT initialized!
eMMC : OK
NAND : OK
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : BOOT 2ND DA FAILED!
ERROR : 000007D4 : BROM : DOWNLOAD DA FAIL
Old 06-10-2019, 20:59   #12 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,305
charge your battery and retry
Old 06-10-2019, 21:40   #13 (permalink)
Member: 496839
Thanks Meter: 14
brother the battery and charge almost 50 percent
Old 06-11-2019, 19:04   #14 (permalink)
Member: 496839
Thanks Meter: 14
Are the problem hard or soft the tablet displays logo acer after fixed on reset
Old 06-14-2019, 21:49   #15 (permalink)
Member: 496839
Thanks Meter: 14
Page generated in 0.44258 seconds with 7 queries
