04-29-2010, 12:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | need file for ztc zt321 "TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W 06_4 4_MP_V3.BI" COM23 [VCP1] selected module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00313FC:E67C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026.[TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN_BBF07969].rpl rom info detection finished ==================== New firmware detected (v.3.11, database date: unknown): TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: B824E026 rom info ver: 05 sw version: TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN project-id: MAUI.06A.W06.44.MP.V3, 6979F0BB code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2BEA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00790000 Detected ffs/eeprom address is non-standard: 00790000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00790000 detecting ffs/eeprom size... ffs/eeprom size: 00870000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00790000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC257E25082501:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\T IANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44_ MP_V3__system_log_B824E026_BBF07969_20100428-125902.B0X.bin Finished, time used: 2 min 8 sec Remove/Install battery now ! |
04-29-2010, 14:52 | #2 (permalink) | |
Member: 383211 Status: Offline Thanks Meter: 131 | Quote:
zm240 v1.0.1 dc2407 | |
04-29-2010, 23:06 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! by any chance automatic EEPROM backup was created duering that format operation? if yes- you can load it as eeprom and write back to phone. phone must be in original state, next you can try format FFS in safe mode |
05-01-2010, 08:46 | #4 (permalink) | |
and write but same problem.now mobile is on and white screen,and key pad is working.this the log of writing firware COM6 [VCP1] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__ffs_20100430-093832.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00313FC:E67C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN_D C1EF6C0].rpl rom info detection finished device-id: B824E026 rom info protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN ver. sw 2: UPU25U26V03B35, C0F61EDC code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__ffs. .. file saved: C:\Program Files\InfinityBox\ChineseMiracle\U26_06B_PCB01_GPR S_MT6226_S01.UPU25U26V03B35__ffs_20100430-183043.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__syste m_log_B824E026_DC1EF6C0_20100430-183102.B0X.bin Area: Eeprom/ffs flash: EC257E25082501:2AEA0000000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__syste m_log_B824E026_DC1EF6C0_20100430-183441.B0X.bin Finished, time used: 508 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [4/30/2010 6:37:01 PM] ==== COM6 [VCP1] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00313FC:E67C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN_D C1EF6C0].rpl rom info detection finished device-id: B824E026 rom info protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN ver. sw 2: UPU25U26V03B35, C0F61EDC code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__ffs. .. file saved: C:\Program Files\InfinityBox\ChineseMiracle\U26_06B_PCB01_GPR S_MT6226_S01.UPU25U26V03B35__ffs_20100430-184134.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25082501:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U 26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__syste m_log_B824E026_DC1EF6C0_20100430-184200.B0X.bin Finished, time used: 295 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Loading file v.02... TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__fullflash_20100428-170016.B0M.bin loaded usb bootloader (file) is absent rom info protocol ver: 05 ver. sw 1: TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN ver. sw 2: MAUI.06A.W06.44.MP.V3, 6979F0BB code offset: 00000000 ffs offset/size: 00E00000/00200000 Loaded file w/protection: startup code area #1 Loading file v.02... TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__ffs_20100430-093832.B0E.bin loaded ==== log: [4/30/2010 6:42:46 PM] ==== COM6 [VCP1] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__fullflash_20100428-170016.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__ffs_20100430-093832.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 00313FC:E67C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN_D C1EF6C0].rpl rom info detection finished device-id: B824E026 rom info protocol ver: 04 ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35.BIN ver. sw 2: UPU25U26V03B35, C0F61EDC code offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B35__ffs. .. file saved: C:\Program Files\InfinityBox\ChineseMiracle\U26_06B_PCB01_GPR S_MT6226_S01.UPU25U26V03B35__ffs_20100430-184736.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.B824E026.[TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN_BBF07969].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.B824E026._TIAN YU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44_MP_ V3.BIN_BBF07969_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026.[TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN_BBF07969].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B824E026._TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAU I_06A_W06_44_MP_V3.BIN_BBF07969_.rpl ==================== warning: unknown rom info structure: TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN_BBF07969 Unknown firmware detected (v.3.02, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait upd | |
05-01-2010, 20:57 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please use latest Chinese Miracle module! here is flash files which is worth to try: flashfiles/ChineseMiracle/_MT6205-MT6227/eeprom/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__eeprom_01.B0E.bin flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Nokia-N77-2sim-PDA_TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W0 6_44_MP_V3_16m_Ru_En_Vn_Cn_Cn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3_16m_En_Cn.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3_Nokia-N82_16m_En_Ru_Fr_De_Pt.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__16m_En_Cn.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__Bluetooth-N77S_16m_En_Ru_Fr_De_Pt.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__v2_16m_En_Cn.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__ZT5168_16m_En_Th_Vn_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6226/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__ZTC-1688_16m_En_Cn.B0M.bin use any flash file together with EEPROM. download latest Chinese Miracle! |
05-03-2010, 16:09 | #6 (permalink) | |
flashfiles/ChineseMiracle/_MT6205-MT6227/eeprom/TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_44 _MP_V3__eeprom_01.B0E.bin flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Nokia-N77-2sim-PDA_TIANYU26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W0 6_44_MP_V3_16m_Ru_En_Vn_Cn_Cn_Ar.B0M.bin | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
