10-18-2015, 18:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Morocco
Member: 382783 Status: Offline Thanks Meter: 124 | need firmeware Motorola W375 Need flash file to flash Motorola W375 dead by other tool . the phone now not power on ,but i can read information. this is information readed with infinity box : Action: read information Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0080_A06 Flex ver: FLEX_AM_00D cpu id: 08B6 imei eeprom: 3558380110675119 required SW version: 0.0.80 Check Flash-1 Done Check Flash-2... Finished, time used: 12 sec Remove/Install battery now ! Thanks . |
10-19-2015, 12:56 | #3 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | Hello sir , i downloaded this flash file from support :w375_6.9.75_K3_firmware.34M . i flashed it by loading firmeware and just checking firmeware Note language pack ,Flex , Eeprom , not checked ). writing flash Done. But still not power on. pls need correct way to flash it. Thanks . |
10-19-2015, 16:42 | #4 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
w375_0.0.80_Main_H80S_K2_1175254689.34M.bin w375_0.0.80_LP_A06_Cn.34P.bin W375_Flex_A4_002_retail[1].34F.bin try this firmeware | |
10-19-2015, 17:40 | #5 (permalink) |
Member: 382783 Status: Offline Thanks Meter: 124 | Hello, After flash , the phone power on with: HELLOMOTO Logo, Phone is hacked : 83 Restart and repeat same problem !!!!!!! "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_AM_00D cpu id: 08B6 imei eeprom: 3558380110675119 required SW version: 0.0.80 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 583801106751_20151019-160707.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 1303 sec Remove/Install battery now ! |
10-19-2015, 18:09 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Check this thread - http://forum.gsmhosting.com/vbb/f296...0411-a-516730/ You can try to unlock phone but I am not sure it will helps. Also you can try to flash phone with another firmware files sets. And who knows what was damaged in phone memory earlier. As I remember in some cases its possible to damaged that Moto phone without chance to get it repared |
10-19-2015, 18:53 | #7 (permalink) | |
Member: 382783 Status: Offline Thanks Meter: 124 | Quote:
The Unlock Solve the problem. Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0080_001 Flex ver: FLEX_A4_002 cpu id: 08B6 imei eeprom: 3558380110675119 required SW version: 0.0.80 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 583801106751_20151019-174324.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 64 sec Remove/Install battery now ! Thanks | |
