12-03-2018, 17:49 | #2 (permalink) |
Freak Poster Join Date: Oct 2012 Location: IRAN.IR ----عل
Member: 1824614 Status: Offline Sonork: ali_f*******[email protected] Thanks Meter: 112 | MT6580__DOOGEE__X55__7.0__DOOGEE-X55-Android7.0-20180825__NRD90M__wd367bf |
12-03-2018, 20:35 | #4 (permalink) |
Member: 1043909 Status: Online Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
12-04-2018, 01:03 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Download: MP_mt6737_n370b_a48-abdelhalim_daoge_cc_64gbitp8d3_m_lte_3m-fdd-cs_mul_20160913-024333_songlixin_PC Release date : 2016/9/13 Latest public original factory flash/rom. I suggest you to make preloader backup, nvram/nvdata backup, and FULL bin rom backup before playing. (from address 0x0 - length: 0xab000000) p.s. boot it by pressing volume up + inserting usb cable. p.s.2 if for some reason you think that you don't like posted rom file - just don't use it and completely ignore my post. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
12-04-2018, 19:09 | #8 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | with doogee x5 ..... always you must : 1-read firmware 2-replace only ( recovery , system, userdata , cache ) in readed firmware with new files from any flashfile ( same model ) 3-flash without preloader ( skip preloader ) 100% tested by me and work perfectly |
12-04-2018, 19:12 | #9 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 395115 Status: Offline Thanks Meter: 7 | Quote:
but now the phone is dead and can't find correct firmware | |
12-04-2018, 22:28 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | We must clear some things here : - Phone was DEAD before flashing ? - Phone flash normally, no any errors ? - You asked for flash file, you got it ? (original, by Doogee factory) As very well known, phones consist of both HARDWARE and SOFTWARE. Hardware may malfunction, like software may malfunction too. Dead phone (no power on state) is rarely SOFTWARE problem, as also well known. So, take some steps like: - check battery, recharge if needed - check if phone display is okay - check board for liquid damage - ask customer of phone history (how that happened that phone became dead). - if customer reply with any sign of "physical damage" (phone dropped, was sitting on it etc.), it is 99.99999999999999% hardware issue. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
12-05-2018, 10:36 | #13 (permalink) | |
first the phone dead after flash... before flashing the problem is hang on logo and after flash is dead but i can flash it normaly just no power on after flash... it's firmware problem am sure. here is info befor flash : Chinese Miracle II [MTK module] v 1.58 Start at : [30/11/2018 / 11:36:39] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 422201F46E69776900001020F1145220 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122 [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi [eMMC] : FLASH_CID : F40122426977696E20100000205283F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0x613BA5FCFB6FAE3947F7C82CA25CE4C6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : DOOGEE ProdName : X5max_S ProdModel : X5max_S Device : X5max_S AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.84_vz6737m.35.i.m0_P50 Done! Elapsed: 00:00:11 | |
