05-02-2019, 07:46 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
05-02-2019, 12:45 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | solved problem Code: Card found: S/N : 7DBA7787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 7.x] Infinity SC Firmware Detected FW Size : 3028 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Just5 Device Model : Konrow Device CPU : Just5 Device IntName : Just5_Konrow Device Version : 7.0 Device Compile : 8/24/2018 7:18:54 AM Device Project : Konrow-Just5-V06-20180824 Device ExtInfo : Just5 Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... Initial Boot Failed! Boot not done, reason : Wrong BootKeys Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down ) Reconnect Power/Cable! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1E records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W18.01.4_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write CodeData : trustos.bin Write Data ... Write Data Ok! Write CodeData : vmm.bin Write Data ... Write Data Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write CodeData : fbootlogo3.bin Write Data ... Write Data Ok! Write CodeData : fbootlogo4.bin Write Data ... Write Data Ok! Write CodeData : fbootlogo5.bin Write Data ... Write Data Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:10:53 Reconnect Power/Cable! |
