10-31-2017, 11:33 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Need firmware Lenovo K5 A7020a48 ( k52_t58) i need this firmware please.... if any one have share.. Thanks Best Regards Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D4206190ED684B29B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD1011772473133A3DEDAD79692322E16 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : k52_t58 ProdModel : Lenovo K52t58 Device : k52_e78 AndroidVer: 6.0 MTKxCPU : MT6755 MTKxPRJ : K52t58_USR_ST1649_5.404.1_1611290103_mp7V2.3_CN Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
11-06-2017, 06:41 | #4 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote: Here is log Code: Start at : [11/6/2017 / 10:39:13 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D4206190ED684B29B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD1011772473133A3DEDAD79692322E16 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : k52_a48 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001BC0000 Erase : 0x0000000004BC8000-0x0000000004000000 Erase : 0x000000000A000000-0x0000000001000000 Erase : 0x000000000B300000-0x0000000002480000 Erase : 0x000000000DC80000-0x000000033E380000 Flash Erase Done, time used : 00:00:01 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [11/6/2017 / 10:39:39 AM] | |
11-06-2017, 23:47 | #5 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
That phone model have signed flash files, and needs to be flashed with checksum verification enabled also. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
11-07-2017, 06:20 | #6 (permalink) | |
and now with cm2 stuck here Selected forced PMT update Build new PMT ... Update Primary ... Main PMT update failed! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! | |
11-08-2017, 00:19 | #7 (permalink) | |
Then read again. After that, read once more - again. b.r. Alex
11-08-2017, 06:58 | #8 (permalink) | |
here is log as i done but problem is still ........................ with_mtk_all_in_one with_DA_SWSECbin with_DA_SWSEC_CRYPTO20bin now tell me what to do??? | |
11-08-2017, 07:43 | #9 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | with latest download tool phone flashed but get error at 83% (DL ERROR) Now phone is powered On but show Error tool DL image Fail. here is pic of flash tool |
11-08-2017, 09:39 | #11 (permalink) | |
also i use newer version v5.1720.00.000 but no luck then i use download tool 1612.8 | |
11-08-2017, 10:57 | #12 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
this is firmware with tool to flash (use DA_agent in firmware folder) https://cloud.mail.ru/public/Di73/S6bXHW8dn password : lenovo-forums.ru | |
The Following User Says Thank You to rebainoor For This Useful Post: |
11-08-2017, 12:48 | #13 (permalink) | |
Finally my phone is alive. | |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
