first I received the phone dead . original firmware is missing in support area ,
i tray to flash with other resembled version , here is the log
==== [16/03/2010 11:59:15] ====
COM3 [VCP1] selected
module v3.10
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
write: Firmware C902E888_PXHT1F11WEL_EVCOM_MT6225S00.GMV11COM_01_0 _20090417__fullflash_20090921-165844.B0M_4.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A903:000E
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
==================== New firmware detected (v.3.10, database date: 02.03.2010):
E880_KDI1MCF10_E880_GPRS_MT6225_S00.01_2.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: E880_KDI1MCF10_E880_GPRS_MT6225_S00.01_2.BIN
project-id: E880_KDI1MCF10.01.2, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/001FF000
TCL-ID is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 11 min 55 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== [16/03/2010 12:12:18] ====
module v3.10
Action: reset settings ("format ffs")
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: E890_EVSMT3B.01.1
Version: EVEN6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35360902302963
connection Ok
building list...
done
items to clear: 166
warning: wrong packet cs
items cleared: 166 of 166
building list...
done
items remains: 0
Finished, time used: 32 sec
phone alive but white lcd
