Old 10-30-2009, 21:06   #1 (permalink)
Member: 28559
Thanks Meter: 85
need firmware for tv38 phone
i have chineese phone that shows progress bar going across the screen counting to 100% then shut off when i press power button.
i need to flash this phone.
i don't see flash on support.
sw 1: U6_PCB04_GPRS_MT6228_S02.U6V10B015.BIN
phone model N38 ZTC
Old 10-30-2009, 21:16   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
phone model N38 ZTC
hi..
did u try to format the phone..? safe format..? and dont forget to take backup...
i have flash file which it has 69 mb but it is not for CM..
Old 10-31-2009, 13:35   #3 (permalink)
Member: 28559
Thanks Meter: 85
i flashed phone with file from support but same problem.
U6_PCB04_GPRS_MT6228_S02.U6V10B015__En_Fr_Vn_Ru_Th _Cn.B4M.bin
phone can't connect when i try format safe mode, check log.
COM8 [VCP0] selected
module v2.96
Action: reset settings
Model: Autodetect 6228-6229 NAND
Checking data, wait...
19200 autodetect
Initializing [6228:8A02:8A02]...
CPU: MT6228
high speed boot On
chip: 0031:0000:0101
status: FF
Connecting at 19200, wait...
warning: wrong packet cs
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 98 sec
Remove/Install battery now !
Old 11-01-2009, 00:03   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what cable do you use?
Old 11-01-2009, 02:31   #5 (permalink)
Member: 28559
Thanks Meter: 85
hello!
i am using pinfinder cable L12C.
Old 11-01-2009, 16:48   #6 (permalink)
Member: 148515
hello!
have you modified your main infinity box to deliver more power to pinfinder?
as it was described in pinfinder user manual
Old 11-01-2009, 22:18   #7 (permalink)
Member: 28559
Thanks Meter: 85
hello!
no i have not modified pinfinder box.
Old 11-02-2009, 17:46   #8 (permalink)
Member: 148515
hello!
i asked about Main Infinity box.
there must be diode removed and shortcutted to deliver more power to its output.
there is usless zenner diode used, where drops 0,7volts.
after shortcutting it- output will be 5,0volts instead of 4,2-4,3
this will dramatically increase power capabilities of pinfinder
and as a result more stable work in test mode
Old 11-02-2009, 18:12   #9 (permalink)
Member: 28559
Thanks Meter: 85
hello!
i have removed diode and short the two contacts. but i get same error when i try to format safe mode
module v2.96
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6228
high speed boot On
status: FF
Finished, time used: 85 sec
Old 11-02-2009, 18:37   #10 (permalink)
Member: 148515
hello!
format it in complete mode and check functionality
Old 11-02-2009, 21:59   #11 (permalink)
Member: 28559
Thanks Meter: 85
hello!
i did format and now phone can boot. i will check functionality and let you know.
module v2.96
Device: Autodetect 6228-6229 NAND
Action: NAND reset
read mode: 01
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6228
high speed boot On
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.02
cpu-id: 07
loader: 3.0840.00.00
NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
external ram: 00000000
finalize connection...
done
load emi configuration...
apply emi configuration...
ram size: 02000000
emi configuration done
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007600AD0076 [04200000]
NOR chip is not installed
Initialize Done
Set baud ...
921600
Set baud Done
Identification ...
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
reading bootloader structure area (00010000 bytes)...
detecting bootloader structure (chip)...
source data: page only
rom info protocol ver: 04
ver. sw 1: U6_PCB04_GPRS_MT6228_S02.U6V10B015.BIN
ver. sw 2: U6V10B015, 00000000
address offset: 00000000
ffs offset/size: 01700000/02900000
nfi area detection finished: Ok
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
Identification Done
Write ...
formatting...
.................................................. .................................................. Write Done
Finished, time used: 45 sec
i Need firmware for Moscow phone Morfy Infinity-Box 0 10-07-2009 16:42
Need NTM version firmware for nokia phone kakala Nokia Base Band 5 ( BB-5 ) 4 06-20-2009 05:40
Russian (and bugfixed) firmwares for Trium phones Anton Mitsubishi 0 03-29-2003 22:09
What last firmware for siemens phones NSerN x1x to x45/x50 1 05-17-2002 13:50
Page generated in 0.20161 seconds with 10 queries
