03-09-2019, 07:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Need flash file KEYTAK60A_M005_CSD_PCB01_gprs_MT6260_S00_BOOTLOADE R_V005.M005_COSTDOWN_ALL_0613_V01 |
09-05-2021, 11:32 | #2 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | TA-1030 clone firmware Quote:
Hi bro. Here is readed firmware by cm2mtk https://www.4shared.com/rar/w9cuHVei...prs_MT62.html? good luck | |
The Following User Says Thank You to ramoon20 For This Useful Post: |
09-05-2021, 12:16 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Thank you! | |
09-05-2021, 13:26 | #5 (permalink) | |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | TA-1030 clone MT6260 firmware Quote:
Hi ser. Yes sure here is https://mega.nz/file/IUcCiJxB#uavMb5...v4hX8BZdQ23F_Y regards | |
09-05-2021, 13:47 | #6 (permalink) |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | ta-1030 clone Hi. Have small problem here menu botton not avaiable i try flashing phone using this firmware nokia 3310 chainn KEYTAK60A_M005_CSD_PCB01_GPRS_MT6260_S00.M005_COST DOWN_ALL_20190111_V01.BIN but not working well alot off bugs inside file so i have backup original flash from phone by cm2mtk and still menu botton not avaiable best regards |
09-05-2021, 14:25 | #7 (permalink) |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | ta-1030 clone Hi infinity teams. I test all 3 file from your support and not working non of them working First one and second one have bugs inside and third one white lcd screen my backup file working well but menu button not avaiable So???? |
09-05-2021, 15:15 | #8 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Read firmware will not work Only factory Firmware can solved this issue in Nokia clone phone You must have to find original factory Firmware |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
09-07-2021, 09:41 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | If you have a problem with different firmware files it means none of them are compatiblem with your phone. You should try to find another similar firmware files and flash it to your phone. |
09-07-2021, 11:59 | #13 (permalink) | |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | ta-1030 clone Quote:
Thanks alot for your quick reply first. Phone come to me with security code and i format it by cm2mtk after set work fine but menu not avaiable Here is format log ========================= Start ========================= 04/09/2021 / 14:04:09 ================================================== ======= Card found : S/N : A42F8960 , v0150 Chinese Miracle II [MTK module] v 1.58 Start at : [04/09/2021 / 14:04:21] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 39FA1D375F9FA33D7449D1456CCCDE2A BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 SDS_INFO : 0x00FFE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00D50000-0x00FFDFFF , LEN : 0x002AE000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:48 Reconnect Power/Cable! Finish at : [04/09/2021 / 14:05:10] If you want i can also upload operation folder Best Regards | |
