03-07-2008, 12:15 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 231650 Status: Offline Thanks Meter: 51 | need flash file for cect c300 COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:9003:0006 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: M350_ABROAD_PCB01_GSM_MT6225_S00.M350_ABROAD_V1_0_ 0.BIN ver. sw2: M350_abroad_V1.0.0, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00700000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00700000 detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[M350_ABROAD_PCB01_GSM_MT6225_S00.M350_ABROAD_V1_0_ 0.BIN]]... file saved: E:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[M350_ABROAD_PCB01_GSM_MT6225_S00.M350_ABROAD_V1_0_ 0.BIN]_20080307-155807.B0E.bin flash: 01227E22022201:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22022201:18E59F00000000 Finalization Done Finished, time used: 142 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! plz kindly advise me which file to flash it to solve the problem |
06-06-2008, 16:16 | #5 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: malabo
Member: 160111 Status: Offline Thanks Meter: 10 | Quote:
if u used safe format and the problem persists then make a backup of the flash and use COMPLETE format option. But please patner can u help me get the pinout of this phone? How did u connect this phone with box? i need to work with it. | |
Need Flash file for CECT T999 | sulaiti | Infinity-Box | 1 | 12-20-2008 22:34 |
Need Flash File For CECT N518 6228 | AsiaGSM™ | Infinity-Box | 9 | 05-11-2008 14:12 |
I need arabic flash file for CECT N95 | GalaxyMan | SpiderMan | 4 | 03-17-2008 04:09 |
help me for select flash file for CECT P168 | zonetrichur | Infinity-Box | 3 | 02-04-2008 21:12 |
Need Flash File Of Cect Q638 | shailesh_chauha | Chinese Cocktail | 1 | 10-23-2007 16:44 |
