06-10-2015, 09:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | PROTEC -Tab MT6582 Read PatternLock : Disabled! how to read Pattern Lock Read Info , Code: Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E4361726420321C74316341CF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E4361726420321C74316341CF [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : PROTEC ProdName : PROTEC ProdModel : 2S3GWFT Device : PROTEC AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.TABLET.MP.V1.12 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E4361726420321C74316341CF DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0088 , OEM : 0103 [eMMC] : FLASH_INF : draC [eMMC] : FLASH_CID : 8801034E4361726420321C74316341CF [eMMC] : FLASH_LEN : 0x00000000E7400000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1023 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock : Disabled! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
06-10-2015, 15:32 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | jaydi bro we want improve cm2 more and more but you want fulldump always its too big size file how can upload i have many mobile some mobile privacy code not read some pattern not read i post already some mobile logs and files |
06-10-2015, 15:52 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
2. I seen FP only. SP - few nand phones. There is something more? | |
