03-12-2009, 15:43 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | n79 dead after formatt ffs hear is full flash : http://rapidshare.com/files/20836147...5.B0M.rar.html COM4 selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9C3E:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.78, database date: 04.03.2009): RATECH23_08A_PCB01_GPRS_MT6223P_S00.Z268_XNWY_MLA_ 1_4T04S1225.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: RATECH23_08A_PCB01_GPRS_MT6223P_S00.Z268_XNWY_MLA_ 1_4T04S1225.BIN ver. sw 2: Z268_XNWY_MLA_1_4T04S1225, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 46 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-12-2009, 19:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Just write back full flash backup and phone will be back in it's original state. 1. restore original full flash backup 2. Try to make "safe" format |
03-14-2009, 23:16 | #5 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
ur fw is damaged.. u havent good full flash i think.. cause it is approx 6 mb.. as far as i know mtk flash file size is 8 or 9 mb.. | |
The Following User Says Thank You to LoveLess For This Useful Post: |
03-27-2009, 12:35 | #7 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | any one post her full flash for this phone: http://rapidshare.com/files/21411278...m-348.rar.html thanks |
03-31-2009, 11:26 | #10 (permalink) |
Member: 636518 Status: Offline Thanks Meter: 175 | hello ...finally here is good flash file for N79...with 8.5 Mo http://rapidshare.com/files/21568071...9.B0M.rar.html -------------------now my phone is working 100/100------------------- so please remouve the bad one and put this..... |
Bleu 255x dead after format ffs | ezysuresh | Infinity-Box | 15 | 11-25-2012 09:12 |
Motorola C139 Dead after flash FFS | valtea | ET-BoX | 5 | 07-13-2008 07:33 |
n95 big dead after formatt | raffazila | Chinese Models & Cloned Phones | 25 | 02-22-2008 07:36 |
KG 300 dead after Format FFS ...... | .::BHATTI::. | Infinity-Box | 4 | 11-19-2007 09:45 |
E330 dead after flash FFS | DonaldDuck69 | UST Pro II | 5 | 02-04-2006 11:36 |
