01-16-2015, 16:59 | #7 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | sure i can arrange if u say with in few min any working ......time i remember me not forget it not have any vol keys no sim some time before some people say me with memory card u can unlock tab if sim option not have u r tab than possible 8 gb card needed but may be its rocker chip not for mtk ...... |
01-16-2015, 17:34 | #8 (permalink) | |
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | yes u r talking about this sure we do it ............... Quote:
Chinese Miracle II [MTK module] v 1.09 Operation : Check / Read Info [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 8127 BB_CPU_HW : CA03 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x00 BLVersion : 0xD8 Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v218.218 on BBID : 0x27 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0000 , [SAMSUNG] K9F5608Q0C [NAND] : FLASH_DIE : 0000 0000 0000 0000 0000 0000 0000 [NAND] : FLASH_LEN : 0x00000000 INT RAM : 0x00000000 EXT RAM : 0x00000000 BOOT TYPE : DONE SOC VERIFY : 00 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND/eMMC init Mode Done! Elapsed: 00:00:21 Reconnect Power/Cable! | |
04-19-2017, 09:46 | #10 (permalink) |
Freak Poster Join Date: Mar 2010 Location: hydrabad sindh
Member: 1266092 Status: Offline Sonork: love Thanks Meter: 17 | htc 320 umlock dan cm2 tool Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040508A1360F9177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040508A1360F9177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB54510BBDCD121E59CC095F38971C583 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
04-19-2017, 10:00 | #11 (permalink) |
Member: 1266092 Status: Offline Sonork: love Thanks Meter: 17 | Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040508A1360F9177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040508A1360F9177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB54510BBDCD121E59CC095F38971C583 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
