05-24-2016, 18:11 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | need flash file Tradeno A7 Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 126 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 700100533130303034084A5CC3B742F1 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 40001 [eMMC] : FLASH_CID : 700100533130303034084A5CC3B742F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 [eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB] DEV RID : C18D33CC29D0447C17176BF19EFE975F INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : A7 ProdName : a6e_ax_youshi_s016_tradeno ProdModel : A7 Device : a6e_ax_youshi_s016_tradeno AndroidVer: 4.4.3 MTKxCPU : MT6572 MTKxPRJ : A6E_AX_YOUSHI_S016_Tradeno_V1.02 Done! Elapsed: 00:00:14 thank you |
